Test & Tools
Test & Tools
Documents Protocol information for Tenma 72-2550 and Tenma 72-2535, Q&A, window driver
  • Author Author: dsohal
  • Date Created: 12 Mar 2015 9:16 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 8:22 AM
  • Views 7569 views
Please check following, if usb is not working.
Please test the software if USB works well or not?
One more thing to be confirmed with the customer as follows:
After you send commands, there will be a beep. Even there is an error; if you confirm USB works well, please check if there is something wrong with the command, for example, there should not be carriage returns or terminator behind the command *IDN?
Therefore, if there is carriage returns or terminator after you type the command, the error will be caused.
Q;TENMA 72-2550 can be controlled with Matlab software?
A:Yes, TENMA 72-2550 can be controlled with Matlab software, as confirmed by supplier.
imageSeries Protocol V2.0 of Remote Control.pdf
USB driver.zip
imageIM - 72-2685 72-2690 72-2695 72-2700 rev.pdf
  • information
  • 72-2550
  • window driver
  • and
  • tenma
  • for
  • q&a
  • 72-2535
  • protocol
  • awneil
    awneil over 10 years ago
    @dsohal - Should "Series" be "Serial" here?
    The document refers to "NR1" and "NR2" parameters - but does not say what these mean!
    To save others having to google these, they are standard SCPI terms:
    <NR1>
    Digits with an implied decimal point assumed at the right of the least-significant digit. Examples: 273
    <NR2>
    Digits with an explicit decimal point. Example: .0273
    See, for example, SCPI Data Formats
  • dsohal
    dsohal over 10 years ago in reply to awneil
    Hi,
         Thank you for your enquiry, please see below for your reply, as I received from our manufacture.
    1. Yes, series here is serial, but only for triple channel power supplies.
    Please check the detailed remote control syntax in the user manual as attached:
    1. ISET1<X>:<NR2>
    Description: Sets the out put current
    Example :ISET1:2.225
    Response time :50ms
    Sets the CH1 out put current 2.225A
    On Page 7, in "ISET", NR2 means the setup value of current.
    3.VSET<X>NR2
    Example: SET 1:20.50.
    SET the CH1 voltage to 20.50V
    On Page 8, , in "VSET", NR2 means the setup value of voltage,
    in the example, the value (NR2) is 20.50V.
  • dsohal
    Hi,
    1. ISET1<X>:<NR2>
    Response time :50ms
    3.VSET<X>NR2
  • awneil
    awneil over 10 years ago in reply to dsohal
    You missed my point:
    It doesn't explain what "NR2" means - as a numeric format.
    As stated, it means a number with an explicit decimal point.
