Test & Tools
Test & Tools
Documents The Rough, Rugged, and Covered in Mud Wishlist!
  • Author Author: dychen
  • Date Created: 10 Jul 2023 8:36 PM Date Created
  • Last Updated Last Updated: 9 Jan 2024 9:50 PM
  • Views 16844 views
  • Likes 10 likes
  • Comments 29 comments
Our Favorite Tools for Engineers in the Wild!
Not all jobs can be done from the comfort of the lab. Engineers often have to venture outdoors and brave the elements, working on devices that are exposed to mud, wind, and sun, or even submerged! This wishlist explores some of the devices that are tough enough to keep up, although bear in mind, most will not survive a plunge into water!
Rough and Rugged Wishlist Giveaway
Answer the question below for a chance to win an Outdoor Rock Speaker!
What's your toughest tool has been through wars in your hands?
We'd love to hear about your roughest projects...and of course, we'd love to see some pictures!
Eight Piece Polished CRV Precision Plier Set
plier set
Buy now
15 Piece Precision Screwdriver Set
precision screwdriver set
Buy now
200mm Vernier Caliper
Mitutoyo Vernier calipers
Buy now
Crimp Tool Set
Multicomp Pro crimp tool kit
Buy now
Gas-powered Soldering Iron
Irodo Gas powered soldering iron
Buy now
Gas-powered Heat Gun
Irodo Gas Powered Heat Gun
Buy now
IP67-Rated Digital Multimeter
Keysight IP67 Digital Multimeter
Buy now
Digital Humidity Meter
Multicomp Pro Digital Humidity Meter
Buy now
Indoor/Outdoor Digital Thermometer
ExTech Digital Thermometer
Buy now
Infrared Thermometer
Fluke Infrared Thermometer
Buy now
IP67-rated LED Strip
TT Electronics Optek LED Strip
Buy now
Waterproof Equipment Case 22.5" x 16.5" x 8.5"
Multicomp Pro Waterproof Weatherproof Equipment Case
Buy now
Waterproof Equipment Case, 10.5"X9.5"X7"
Multicomp Pro Waterproof and Weatherproof Equipment Case
Buy now
Waterproof Tool Case
PEL Tool Case
Buy now
IP67-rated Weatherproof Enclosure for Raspberry Pi, Arduino, Beaglebone, and more.
OpenH.IO IP67 Case for Raspberry Pi, Arduino, Beaglebone
Buy now
Stellar Labs Outdoor Rock Speaker
Buy now
  • durable
  • dustproof
  • outdoor
  • portable
  • rugged
  • weatherproof
  • ip67
  • handheld
  • wishlist
  • gas powered
  • waterproof
  • srutledge
    srutledge over 3 years ago +3
    Hello everyone! I'd like to congratulate the winners of our giveaway: JWx colporteur wolfgangfriedrich dougw If you have not already received your prize, it should be in the mail and on its…
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to srutledge +2
    Thanks a lot. I am with colporteur on this one. Would be a great improvement for my Halloween 0.5W speaker in the Scare-O-Matic.
  • JWx
    JWx over 3 years ago +1
    multitool of course - mine is somewhat worn-out, but those brand-named seem too good-looking for actual use...
    dougw over 3 years ago
    If you want a tool for the wild, you need to know about the cutlass. I grew up in a jungle and there was simply no more important or versatile tool than a cutlass. The one pictured at the top of this image with my initials carved in the handle has been used for an incredible number of tasks and it has been sharpened so much, most of the blade is gone, but it still has many uses. Below the cutlass is a machete which shows a bit of blade has been sharpened off - for a size comparison. Both are over 50 years old. The amount of sharpening damage shows their relative importance - there is no contest - the cutlass is a far superior tool. I wouldn't call myself an expert in cutlass use because I have seen real experts do absolutely amazing things with a cutlass.
    Unfortunately my cutlass no longer looks or performs like a cutlass but below is a picture showing what the cutlass should look like (much longer than a machete) and proving that I am not the only one who thinks they are great. Going into what we called the bush (what others call the jungle) is a serious business and if you are going into the bush, your first and only choice of tools is a cutlass. If you are going for a long time, your second tool would be a file to sharpen your cutlass. That is it, no other tools are needed. This picture lists only a tiny fraction of the uses for a cutlass.
    It isn't easy describing my passion for this tool. I am a bit of a tool-a-holic and I've done engineering work in some pretty rough places, but I have never come across anything that compares to the utility of a cutlass in the jungle.
    beacon_dave over 3 years ago in reply to dougw
    I'm surprised that 'shave beard' isn't on that list of uses Slight smile
    dougw over 3 years ago in reply to beacon_dave
    Although the list is missing about one hundred real uses, shaving is not one I've seen. I'm not sure a $3 cutlass sharpened with a file is going to make a great razor.
  • JWx
    JWx over 3 years ago in reply to beacon_dave
    nobody shaves if he thinks he can get away with it?
