Test & Tools
Test & Tools
Forum Operation of simple Li-ion Battery Charge System
  • Replies 19 replies
  • Answers 12 answers
  • Subscribers 362 subscribers
  • Views 3182 views
  • li-ion charger
jw0752
jw0752 over 7 years ago
I am testing out a cordless screw driver. When I first plugged it into the charger a red LED light was suppose to light but it didn't. After a couple hours I opened the unit up and checked for circuit problems,
The SOT89 in the center right of the circuit board is a B772 NPN transistor and it controls the charge current. Below it, the small transistor is a 2N7002 ( an N Ch MOSFET) and it is the driver that controls the B772. The U1 which I haven't IDed is probably the charge controller. When I first opened the unit I had 5 volts on the emitter of the B772 and no volts on the Collector. The Li-ion battery was sitting at 0.6 volts. In the course of my testing I eventually put a small token charge into the battery and at this point the unit started charging as normal.
My question is this: Did the extremely low charge level of the battery cause the charge circuit to default to a no charge situation or is there likely a secondary fault in the circuit that has just decided to temporarily heal itself? Any insights would be appreciated. I have minimal experience with this type of charging circuit.
    genebren over 7 years ago +9 verified
    John, I am working on a Li-ion battery charger right now (and I have developed others in the past). Most of the Li-ion chargers have a 'battery check' (injecting a small current into the battery and looking…
    mcb1 over 7 years ago +8 suggested
    You should know by now that anything that is broken, always works when you take it to get fixed ... It wouldn't surprise me if the low voltage caused the charging to shut down. Lithium Ion cells shouldn…
    jw0752 over 7 years ago in reply to genebren +7
    Hi Gene, that is exactly the info I was looking for. There was some crystallized spillage on the circuit board which would have provided a discharge path for the battery while it was still liquid. It looked…
    0 mcb1 over 7 years ago
    You should know by now that anything that is broken, always works when you take it to get fixed ... image
    Lithium Ion cells shouldn't go that low, so don't be surprised if the battery performance is reduced either in capability or life.
    The best source of information is here.  http://batteryuniversity.com/
    Charging information http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
    • Vote Up +8 Vote Down
