Ask an Expert Forum How do you connect LED's in parallel?
  • Replies 7 replies
  • Subscribers 303 subscribers
  • Views 3165 views
  • electronic circuit design
  • led array
See a helpful answer?
colporteur
colporteur over 5 years ago
I have a need to connect a number of LED's in parallel. Can someone share their insight into why an additional resistor is required for the LED's of different colour in parallel to light?
The LED's in circuit A lights with no issues. In circuit B, only the Red LED lights. Circuit C lights both LED's but requires the extra resistor to achieve the success.
My formal electronics training occurred when vacuum tubes were still common in electronics. My understanding would be voltage drops. The Green LED requires a higher voltage drop to light than a Red LED. Circuit B doesn't light because the Red LED lights with it's voltage drop not being sufficient for Green to light.
I appreciate this is a pretty simplistic circuit. I find for myself exploring the basics refreshes the knowledge retained in my magnetic core memory:)
  • geralds
    geralds over 5 years ago +3
    Hi, this is just a basic calculation. The datasheet describes more details. Best Regards Gerald ---
  • neilk
    neilk over 5 years ago in reply to colporteur +3
    Sean, have a look here (sorry about the length of the URL): https://reviseomatic.org/help/e-diodes/Diodes%20Light%20Emitting.php#:~:text=LEDs%20emit%20light%2C%20only%20when%20they%20are%20forward%20biased…
  • colporteur
    colporteur over 5 years ago in reply to neilk +3
    Thanks for the resource link. I wish I was sitting across the table at coffee break with a napkin to better generate an understanding.
  • geralds
    Best Regards
    Gerald
  • colporteur
    colporteur over 5 years ago in reply to geralds
    That is where the waters get muddy.
    You would think the Green would work and the Red not when they are in series without the resistor. That is not the case. I can't work out the voltage divider to arrive at the bias voltage on the device.
  • neilk
    https://reviseomatic.org/help/e-diodes/Diodes%20Light%20Emitting.php#:~:text=LEDs%20emit%20light%2C%20only%20when%20they%20are%20forward%20biased.&text=Typical%20LEDs%20have%20about%202,colour%20and%20type%20of%20LED).
    Includes forward bias voltages for all colours and says "LEDs in parallel - bad idea; LEDs in series - OK"
    Neil
  • neilk
    Neil
  • colporteur
