      • Japan
      • Vietnam
WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Advanced DMM Tips & Tricks - Workbench Wednesdays 61
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 8 Sep 2022 8:25 PM Date Created
  • Last Updated Last Updated: 28 Sep 2022 7:24 AM
  • Views 105259 views
Digital multimeters (DMMs) can measure multiple things. But they can do more than just what their dial suggests. For example, you can use diode mode to measure a MOSFET. Or you can use resistance mode to check if a DMM fuse is bad. These are seven tricks that James does with his DMM that go beyond voltage and current measurements.
Supplemental Content:
  • Unique DMM Tips / Tricks / Measurements Forum Discussion
  • Workbench Wednesdays #11: Instrument Basics: DMM
  • Workbench Wednesdays #19: Four-Wire Resistance Measurements
  • Workbench Wednesdays #23: What that DMM Beep Means - A Continuity Mode Tutorial
  • Workbench Wednesdays #21: DMM Half-Digital Explained
Bill of Materials
MP730651 Handheld Digital Multimeter Multicomp Pro 1 Buy Now
MP770521 Test Lead Set, Banana Plug Stackable, Alligator Clip, Banana Plug, Hook Clip Multicomp Pro 1 Buy Now
1 Kohm, metal, 1% resistor Multicomp Pro 1 Buy Now
Small Signal: 1n4148 Multicomp Pro 1 Buy Now
Zener: 9.1v, 1n4739a Multicomp Pro 1 Buy Now
MP000438 LED, Blue, Through Hole, T-1 3/4 (5mm), 20 mA, 3.2 V, 467 nm Multicomp Pro 1 Buy Now
LED, Green, SMD, 1206, 20 mA, 2.1 V, 570 nm Multicomp Pro 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • mosfet
  • digital multimeter
  • diode
  • dmm
  • led
  • multimeter
  • bjt
  • baldengineer
    baldengineer over 3 years ago in reply to koudelad
    haha.
    Yeah, I like to change things up every so often.
    I am glad someone noticed!
  • koudelad
    koudelad over 3 years ago
    Very good episode, thank you, James. Nice tips everyone should be shown at school :)
    I was also a bit nervous that the "welcome back" has gone, but I have already seen newer episodes and relaxed.
    DAB over 3 years ago
    Good episode.
    I went through Tech School with the analog meters.
    It was a lot of years before I went digital.
    Nice to know that even an old dog like me can learn new tricks.
  • baldengineer
    There was a YouTube comment regarding my comment that the milliamp path measured 10 megaohms because of the slow-blow fuse.
    I remember hearing a long time ago that a slow-blow has a higher resistance. But I must have remembered that wrong.
    On other DMMs, I have always measured mega-ohms on milliamp terminals.
    Did I misunderstand something I learned a long time ago? Are these measuring so high because that's the shunt resistance of that path?
