Blog Stirling Blue - TNT Ignition - Blog 13
  • Author Author: dougw
  • Date Created: 20 Jul 2018 8:35 AM Date Created
  • Views 2022 views
  • Likes 8 likes
  • Comments 8 comments
  • micro:bit
  • type-n-text
  • doug wong
  • tnt
  • bluetooth unleashed
  • bluetooth unleashed design challenge
dougw
dougw
20 Jul 2018
This blog wraps up work on the Type-N-Text (TNT) devices. It has come right down to the wire with only hours left in the challenge and I really wanted to get these devices working. I miscalculated the amount of effort the project would take pretty badly so everything would have had to go perfectly in the last 2 week to complete everything I wanted to achieve. But of course things weren't going to go perfectly and they definitely didn't. After completing the micro:bit-to-PSoC communication in the last blog, it should have been a simple matter of whipping up a little radio program. However the IDE was unable to load the radio library. It turns out I had to upgrade to the latest IDE to have radio support. The latest editor version does have radio support, but it totally broke my existing code, refusing to configure the micro:bit pins the way they were designed to work - and were working fine in the old IDE. This was a major setback with just one day left in the challenge, but I decided to put my head down and just focus on getting the TNT working. I had to go back to the drawing board, develop new schematics, tear the devices apart, rewire them, reprogram the micro:bits to reflect all the changes and then debug some nasty ping-pong run-on issues. So here it is about 5am on the final day and still trying to get the blog published.
At least the effort paid off in a working system as you can see in this video:
There is nothing like having to redesign, teardown, rebuild and reprogram a 3 month project in one evening I may sound a little tired in the video....
I don't really have time to publish all the material I have on Stirling engines and further work with the PSoC6, but I will try to make a wrap-up blog.
Related Links:
Bluetooth Unleashed Design Challenge: The Challengers
Bluetooth Unleashed Design Challenge: About This Challenge
Links to other blogs for this project:
Stirling Blue - Project Description - Blog 1
Stirling Blue - Unboxing Hero - Blog 2
StirlingBlue1
Stirling Blue - micro:bit TXTR - Blog 3
Stirling Blue - Fuel Measurement - Blog 4
FuelMeasurement1
Stirling Blue - Interface Description - Blog 5
Stirling Blue - BBC micro:bit LCD - Blog 6
microbitLCD1
Stirling Blue - Power Measurement - Blog 7 (updated)
PowerMeasurement1
SpeedMeasurement1
Stirling Blue - Bluetooth Terminal Awakening - Blog 8
BluetoothTerminalAwake1
Stirling Blue - PSoC Bluetooth Terminal Keyboard - Blog 9
PSoC4KeyboardScanning1
Stirling Blue - Bluetooth Terminal - First Contact - Blog 10
BluetoothTerminal1stContact
Stirling Blue - micro:bit QWERTY keyboard & LCD - blog 11
MicroBitKeyboardLCD
Stirling Blue - TNT (Type-N-Text) - blog 12
TNT1
    mcb1 over 8 years ago +4
    Well done. Yes it is frustrating when all your hard work gets undone by what should be a simple upgrade. Good luck I'm sure there will be a few hours room for your completion. No-one can deny you this…
  • aspork42
    aspork42 over 8 years ago +3
    Glad you found a use for that old floppy disk Great case! For buttons, i try to link the together inside the case to keep them all lined up; so it is one big piece instead of many.
    dougw over 8 years ago in reply to mcb1 +2
    have to go to work now. Lots of meetings scheduled....
    Well done.
    No-one can deny you this surely.
    have to go to work now. Lots of meetings scheduled....image
    mcb1 over 8 years ago in reply to dougw
    Yes work getting in the way of life ...
    I meant the closure time of the Challenge.
    Surely a few more hours given the magnitude and complexity, without having the added issues thrown at you.
