Experimenting with Extreme Environments
  • Experimenting with Extreme Environments
Blog PicoPorch and ComputeCam - The Motor System
Join Experimenting with Extreme Environments to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 29 Apr 2024 6:14 AM Date Created
  • Views 1101 views
  • Likes 10 likes
  • Comments 5 comments
  • PicoPorch
  • Pi CM4
  • Hammond 1554VA2GYCL
  • Hammond Manufacturing
  • ComputeCam
dougw
dougw
29 Apr 2024
Intro
This update in the experimenting with extreme environments design challenge focusses on the motor mechanism which allows the camera in a Hammond enclosure to pan across the yard.
The Motor System Video
Update
The intended motor actually arrived, so I have added this update to show what it looks like. It works better than the backup and will definitely stay in the project.
It did require more 3D design and printing, but it was worth it.
Discussion
So far the project has already required at least eleven 3D printed parts, which are taking lots of time to design and print, but there are still several key structures to be designed.
The motor mechanism is now working well considering it is using a backup gearmotor, which causes it to rotate faster than I would like. I may try to slow it down with PWM once the motor controller PCB is assembled, but I'm not sure that will work any better than a series resistor.
Update The real motor arrived and has eliminated any need for further slow downs.
I have completed the Pico/display PCB and it is on order, but will not arrive for some time. The first PCB (motor controller) has arrived but is still missing a couple of FETs.
The Compute Module 4 camera cable has not arrived either, so getting it running has been delayed.
Overall, the project has some decent progress and some delays that are a bit concerning - basically a common state for these kinds of project to go through.
The next focus will be on building the power supply system.
Links:
  • Garden Secrets System
  • ComputeCam and PicoPorch - Early Muddling
  • PicoPorch and ComputeCam - The Motor System
  • PicoPorch - LCD PCB & Bezel
  • PicoPorch power wiring
  • PicoPorch Motor Controller Demo
  • PicoPorch System Demo
  • PicoPorch Final Touches
  • Deep Dive On Kit Components
  • Backyard Secrets 1
  • MotionEyeOS Tutorial
  • Garden Secrets Project Summary
  • Experimenting with Extreme Environments Design Challenge
  • Pi 4 Compute Module Datasheet
  • Pi 4 Compute Module I/O Board Datasheet
  • Midas Display Datasheet
  • Enclosure Drawing
  • Enclosure Manufacturer Page
  • Antenna Datasheet
  • Connectors Datasheet
      DAB over 2 years ago in reply to dougw
      Looking at your design, you could put the motor inside the enclosure with a rubber gromet around the motor shaft to keep the electronics dry.
      dougw over 2 years ago
      I finally received the intended motor, so a video has been added to show it in action.
      dougw over 2 years ago in reply to DAB
      I am not worried. Either I find a way to shield it from moisture, or it dies and I have a great example of why the Hammond enclosure is needed. I may put a fuse on the power to the motor.
      Very cool Douglas.
      Are you worried about the motor being affected by weather?
    • javagoza
      javagoza over 2 years ago
      I am barely able to manage time with a simple design like the one in my project, everything you have proposed is amazing. The rotating box is a pleasant surprise. Best of luck with your next steps!
