Design Challenges
Design Challenges
Forum RDM3600 RFID COMPONENT
  • Blogs
  • Replies 29 replies
  • Subscribers 8 subscribers
  • Views 4812 views
I have been using the Arduino platform for a while now(about 6 months) and I tried to hook up the RDM3600 RFID reader to my Arduino Uno and it seems like the reader does not communicate with the board. I present a card, but the serial interface does not display a serial number or anything. I am following this tutorial:
http://tronixstuff.com/2013/11/19/arduino-tutorials-chapter-15-rfid/
I modified the code to get an indication that the setup was complete:
#include <SoftwareSerial.h>
SoftwareSerial RFID(2, 3);
int i;
void setup()
  RFID.begin(9600);
  Serial.begin(9600);
  Serial.println("ready");
void loop()
  if (RFID.available() > 0)
    i=RFID.read();
    Serial.print(i, DEC);
    Serial.println(" next");
Does anyone have any idea why I don't get any communication from the RDM3600 when I present a RFID tag.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    Are you trying to use Mifare tags? If so they operate on 13.56MHz.
    I've just purchased one of these modules, so I should have a better idea whats going on in a couple of days.
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    I think my problem is I'm using RFID tags that operate at a higher frequency than the 125kHz that the reader uses.
    I ordered some new tags, I will keep you posted.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to gadget.iom
    Here is the code I was using:
    SoftwareSerial RFID(10, 11);
    int i;
    void setup() {
      RFID.begin(9600);
      Serial.begin(9600);
    void loop() {
      if (RFID.available() > 0) {
        i=RFID.read();
  • gadget.iom
    Ok. I tested the code on an Arduino Leonardo, With a USB-232Serial(TTL) adaptor connected to pin 10. When I copied you code over and changed 3,4 to 10,11 in the SoftwareSerial declaration I received the ascii code number followed by the word "next".
    For example pressing 1 resulted in "49 next". I used a cable like this http://uk.farnell.com/ftdi/ttl-232r-3v3/cable-usb-to-ttl-level-serial/dp/1329311 and a separate Serial Terminal program to send the data to the Arduino.
    Still no luck...
  • gadget.iom
    It is likely due the limitations outlined on this page: Arduino - SoftwareSerial
  • gadget.iom
    Ok. Have spent some time playing with this...Try changing your SoftwareSerial pins from 3&4 to 10&11. Connect your RFID reader to pin 10.
    When I link pin 3 and pin 0 I can send a value via the serial monitor that appears on the the monitor. What does this mean?
    Thank you
  • gadget.iom
    Thanks. I will test this as soon as I get back to my Arduino.
