In the Air Design Challenge
  • In the Air Design Challenge
Blog In-the-Air-Challenge: Spending the 500 USD parts budget
  • Author Author: janisalnis
  • Date Created: 28 Jan 2015 9:13 PM Date Created
  • Views 1320 views
  • Comments 5 comments
janisalnis
janisalnis
28 Jan 2015
Previous post:  In-the-Air-Challenge: A sheet of laser light for 2D visualization of dust flow
Next post: In-the-Air-Challenge: Measuring CO2 levels during lectures with EXTECH CO2 monitor
Almoust at the last moment I compiled a list of 500 USD budget for the parts of the challenge that amounts ca 430 EUR in Jan. 2015.
I was very impressed that Christian Defeo at Element 14 ordered everything in a couple of hours after I sent him an email with the long list. I was mostly interested in optical CO2 meter. Price for it varied a lot at Farnell webshops in different countries. I used prices from Germany website http://de.farnell.com/ to add up to 430 EUR. And that was fine. No added VAT. Thanks a lot to Farnell.  The parts arrived to my home address with UPS truck in a couple of days. They were sent from UK location.
EXTECH INSTRUMENTS  CO100  METER, CO2, 9999PPM, 99.9%
197,71 €
http://de.farnell.com/extech-instruments/co100/meter-co2-9999ppm-99-9/dp/2081081?ost=co100&categoryId=700000005821
I will use this near-infrared non-dispersive type CO2 sensor to compare with electrochemical CO2 sensor module. NDIR sensor is callibrated against NIST traceable device, accuracy 75ppm or +-5%.
Good <800 ppm
Normal 800...1200 ppm
Bad >1200 ppm
First tests in the sleeping room at home showed that air was OK bad during the night 700...800ppm. In a confined space like a toilet CO2  content rised to 2000 ppm within 5 minutes. I will test the device during the lecture with ca 20 people this week.
This model has an empty battery compartment and USB hole is not populated. I will try to see if there is some place inside where analog voltage could be accessed with MSP430 or CC3200 and sent to IoT over Wi-Fi.
TEXAS INSTRUMENTS  OPA350UA  OP-VERST., HIGH-SPEED, R/R-I/O, SOIC 350
2,35 € * 4 pieces
http://de.farnell.com/texas-instruments/opa350ua/op-verst-high-speed-r-r-i-o-soic/dp/1106197
This single-supply OPamp I plan to solder this week in a home-made dust particle counter to amplify photodiode signal after schematics in paper:
A. Morpurgo et al , "A low-cost instrument for environmental particulate analysis based on optical scattering"
ANSMANN  1209-0000  STROMVERSORGUNG AC/DC, APS600 TRAVELLER
19,42 €
http://de.farnell.com/ansmann/1209-0000/stromversorgung-ac-dc-aps600-traveller/dp/1973938
Adjustable voltage 3...12V in steps. Current 600 mA. switching power supply adapter.
RASPBERRY-PI  RPI CAMERA BOARD  RPI KAMERA-BOARD, 5MP, MIT FLACHKABEL
19,25 €
http://de.farnell.com/raspberry-pi/rpi-camera-board/rpi-kamera-board-5mp-mit-flachkabel/dp/2302279?ost=RASPBERRY-PI+-+RPI+CAMERA+BOARD+-+RASPBERRY+PI+CAMERA+BOARD%2C
I would like to test this camera with RPi and compare with USB camera Logitech C270 that I use on Beagleboard/Rpi.
HAMMOND  1590B  DRUCKGUSS-GEHÄUSE, 60.5X112X31MM
7,01 € * 2 pieces
http://de.farnell.com/hammond/1590b/druckguss-geh-use-60-5x112x31mm/dp/3061590?ost=HAMMOND++1590B++ENCLOSURE%2C+INSTRUMENT%2C+ALUMINIUM
Nice shielded alu boxes.
IST INNOVATIVE SENSOR TECHNOLOGY  P1K0.0805.2P.A  SENSOR, PT1000, SMD0805, KLASSE A
7,16 €
http://de.farnell.com/ist-innovative-sensor-technology/p1k0-0805-2p-a/sensor-pt1000-smd0805-klasse-a/dp/1266951
This platin wire sensor is good for absolute callibration of other sensors.
SAMSUNG  MMCTR08GUBCH-RMLMK-FARN/KIT  SPEICHERKARTE, MICRO-SD, NOOBS, JAVA 8GB
7,58 €  * 3 pieces
http://de.farnell.com/samsung/mmctr08gubch-rmlmk-farn-kit/speicherkarte-micro-sd-noobs-java/dp/2428393
BELDEN  8723  KABEL, GESCHIRMT 2PAARIG 22AWG GRAU LF.M
1,39 €    * 5 meters
http://de.farnell.com/belden/8723/kabel-geschirmt-2paarig-22awg/dp/1218667?ost=BELDEN+-+8723+-+SHLD+CABLE%2C+2+PAIR%2C+22AWG%2C+GREY%2C+PER+M&categoryId=700000006049
Basically similar cable as used for USB.
  • hlipka
    hlipka over 11 years ago
    430 EUR? Seems that the recent changes in exchange rate take their toll (my limit was still 375...) But you used to get your hands on really nice stuff
  • hlipka
  • janisalnis
    janisalnis over 11 years ago in reply to hlipka
    EUR got constantly weaker against USD since July. Can see it from gold price. Probably because of sanctions.
