In the Air Design Challenge
  • In the Air Design Challenge
Blog In the Air Design Challenge - Pollen & Allergen Sensing – Post 5 (InTheAir Power Board)
  • Author Author: tomaja
  • Date Created: 21 Dec 2014 11:08 PM Date Created
  • Views 913 views
  • tps61200
  • iot_pollen
  • eagle
  • wuerth
  • bq25504
  • in_the_air
  • lipo
  • solar
tomaja
tomaja
21 Dec 2014
Previous posts:
In the Air Design Challenge - Pollen & Allergen Sensing – Post 1 (Pollen Sensor)
In the Air Design Challenge - Pollen & Allergen Sensing – Post 2
In the Air Design Challenge - Pollen & Allergen Sensing – Post 3 (AirVantage Intro)
In the Air Design Challenge - Pollen & Allergen Sensing – Post 4 (Preparing the InTheAir Power Board)
This time I will provide just a small update on the solar power PCB.
I will send it out for fabrication to WE Direkt in a couple of days. Based on the quote on Wuerth site, PCB should arrive in 9-10 days after I order them.
In the meantime, I made some design change. Since there are preset versions of TPS61200 I decided to use them for both 3.3V and 5V supply.
Please keep in mind that I'm not a professional so there may be some fundamental design faults. Comments and directions from professionals are more than welcome.
Here's my PCB design for the solar power board:
Eagle files can be found in the attached .zip archive but I also created a BitBucket repository: https://bitbucket.org/tomaja/intheair-solar-power-board
Please note that I didn't set resistor values for BQ25504 voltage dividers (ROV, RUV and ROK) since these values depend on battery type and desired limits.
I will soon provide the link to cross-platform InTheAir client application source code - it's still not good enough to be published.
Thanks,
Dragan
SolarPower.zip
    shabaz over 11 years ago +2
    Hi Dragan, This looked good to me. I followed the circuit against the datasheets schematics, and it seems to look good. Good luck!!
    I was going to add this to a recent post of mine but I forgot. Since you are sending your files for fabrication soon, I figure I can post it here : ) It is a rule that I use for reducing the risk of PCB…
  • tomaja
    tomaja over 11 years ago in reply to shabaz +1
    He he Your rule can be applied to many jobs: Don't spell check late at night, Don't send important emails... Thanks for checking it! Dragan
    It is a rule that I use for reducing the risk of PCB error image
  • tomaja
    He he image Your rule can be applied to many jobs: Don't spell check late at night, Don't send important emails...
    Dragan
