Upcycle It
  • Upcycle It
Upcycle It
Blog PDU #12-3 - Another Improvement in Function Consolidation [Upcycle It Challege]
  • Author Author: jasonwier92
  • Date Created: 23 May 2017 10:23 PM Date Created
  • Views 843 views
  • node-red
  • upcycle it
  • upcycled_pdu
jasonwier92
jasonwier92
23 May 2017
My outlet control is next on the list to fix up.
What it was: (can you say nasty)
What I need is a way to tell which kind of message came in.  Lets see what they look like.
So if I can test for the existence of msg._session and msg.topic, I should be able to know which message came in and where to send out out.  So I took my existing function and added a new section, based off the fact if it is a MQTT or WS message.  Here is my function code now.
if (msg._session) {
    var jMsg = JSON.parse(msg.payload);
    console.log(jMsg);
    var nMsg = { payload: "0" }
    if (jMsg.state == "on")
        nMsg.payload = "1";
    if (jMsg.outlet == "outlet1") {
        return [null,null,null,null,null,null,null,nMsg];
    if (jMsg.outlet == "outlet2") {
        return [null,null,null,null,null,null,nMsg,null];
    if (jMsg.outlet == "outlet3") {
        return [null,null,null,null,null,nMsg,null,null];
    if (jMsg.outlet == "outlet4") {
        return [null,null,null,null,nMsg,null,null,null];
    if (jMsg.outlet == "outlet5") {
        return [null,null,null,nMsg,null,null,null,null];
    if (jMsg.outlet == "outlet6") {
        return [null,null,nMsg,null,null,null,null,null];
    if (jMsg.outlet == "outlet7") {
        return [null,nMsg,null,null,null,null,null,null];
    if (jMsg.outlet == "outlet8") {
        return [nMsg,null,null,null,null,null,null,null];
if (msg.topic) {
    var topic = msg.topic;
    if (msg.payload == "ON")
        nMsg.payload = "1";
    if (topic == "tower/outlet0001/control") {
    if (topic == "tower/outlet0002/control") {
    if (topic == "tower/outlet0003/control") {
    if (topic == "tower/outlet0004/control") {
    if (topic == "tower/outlet0005/control") {
    if (topic == "tower/outlet0006/control") {
    if (topic == "tower/outlet0007/control") {
    if (topic == "tower/outlet0008/control") {
And now it looks like this.
So much better. In 12-2 I wondered if HASS would do MQTT JSON switches and the answer is no. Also Home Assistant can use Web Sockets, so you could use Node-Red for your Home Assistant automation.  This is nice, because HASS's automation is clunky, limited, and you have to reload the config after each change.
  • Workshopshed
    Workshopshed over 9 years ago +1
    Node-Red is powerful but a side effect of that is that there are many ways to solve any problems.
    DAB over 9 years ago +1
    One of the nice benefits to learning Object Oriented Analysis is that it trains your mind to think of these types of consolidation before you begin coding. Saves a lot of time in development and testing…
    Saves a lot of time in development and testing.
