Upcycle It
  • Upcycle It
Upcycle It
Blog Upcycle It - Funeka - The Skull #4 : The Anatomy
  • Author Author: sakthi.1260
  • Date Created: 17 Apr 2017 2:24 PM Date Created
  • Views 745 views
  • upcycled_funeka
sakthi.1260
sakthi.1260
17 Apr 2017
Hi guys,
Say hello to funeka, the skull.
After salvaging the parts and before ruining the skull i took a close look of the skull and started to clearly plan out things.
The jaw were attached using a set of springs.
those were really hard springs, the motor or the stepper couldn't have enough torque to pull it.image
So I decided to replace the spring with a piece of elastic so the motor could pull.
Further placing a motor on the top is not possible, again the same torque issue.So decided to keep the motor below the skull inside the box. So I put a screw
and the tiny motor is able to pull it image.imageimage
I ordered a pair of doll eyes from, this came the eyes are too small but, I decided to use them as such. imageimage
For the ocular movement,I've designed a simple mechanism i'll be 3d printing shortly, Have decided to control them using the servo that came in the Grove Starter Kit. Since I've been provided with two Intel Edisons, I'm also thinking of using them both, since they'll help in reducing code complexity and will save a lot of time. The other steppers and motors I extracted??, I've planned something else image
Cheers,
Sakthi
  • sakthi.1260
    sakthi.1260 over 9 years ago in reply to DAB +2
    DAB over 9 years ago +1
    Nice post. I see a lot of interesting variations on your plan. Lots of uses for an automated skull. DAB
    Nice post.
    Nice post.
  • sakthi.1260
