Upcycle It
  • Upcycle It
Upcycle It
Blog [Upcycle It] Interactive Race Car Driver - Indicators - Offline testing with node and mraaStub
  • Author Author: Workshopshed
  • Date Created: 16 May 2017 5:22 PM Date Created
  • Views 683 views
  • upcycled_interactiveracecardriver
Workshopshed
Workshopshed
16 May 2017
For my indicators, I wanted a simple function that would blink them 5 times then stop. I found a suitable piece of code on Stack Overflow which did the same thing for some flashing text and ported it across to node. However, I did not have the Edison to hand so pondered how I would test it. A quick google found mraaStub  a mock version of mraa that you can use on platforms that don't have mraa hardware. I installed this and discovered that it needs a logging package called "winston" which I also installed. I also had to tweak the mraaStub library so that it would log by default. My version can be found at https://github.com/Workshopshed/UpcyclingDesignChallenge/tree/master/mraaStub
//Simple function to test the indicator
var platform = require('os').platform();
var m;
if (platform === 'win32') {
    m = require('mraaStub'); //also needs winston
} else {
    m = require('mraa');
var myLed = new m.Gpio(13); //LED hooked up to digital pin 13 (or built in pin on Galileo Gen1 & Gen2)
myLed.dir(m.DIR_OUT); //set the gpio direction to output
function indicate() {
    var count = 1;
    var ledState = true;
    var intervalId = setInterval(function() {
        myLed.write(ledState?1:0);
        ledState = !ledState;
                if (count++ >= 10) {
                clearInterval(intervalId);
    }, 500);
indicate();
Here's how it looks in Visual Studio Code when it is running.
Reference
javascript - Making text blink a certain number of times? - Stack Overflow
https://www.npmjs.com/package/winston
https://www.npmjs.com/package/mraaStub
https://github.com/Workshopshed/UpcyclingDesignChallenge/blob/master/Tests/test6.js
Previous Posts
Upcycle It Blogs tagged with upcycled_interactiveracecardriver
  • Workshopshed
    Workshopshed over 9 years ago +1
    One simplification of this approach is to rename the "node_modules\mraaStub" folder on the Windows development machine to be "node_modules\mraa" then code can be simplified to be: var m; m = require(…
  • Workshopshed
    Have updated this to include pwm support
  • Workshopshed
