Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Small Models
  • Date Created: 23 Aug 2015 11:16 PM Date Created
  • Views 1677 views
  • Comments 6 comments
  • solar_farm
Small Models
e14 Contributor
e14 Contributor
23 Aug 2015
So, I am going to create a 1-2 level aquaponic farm with some really small unedible fish- like the ones at the pet store. I guess I will feel bad about giving them away later, but I need to fix up a smaller module to make sure that my parts are right. Basically it will have a 30 gallon tank for the beginning, a ph sensor and possibly some other chemical sensors.(Have to check exactly what I need) I bought the parts yesterday, and am going to the local Home Depot(again) because I forgot about the wall adapters for the pump. (Shopping at ten PM is really tiring xD).  I will use a relay to control the pump(130 gallons per hour), but as far as I can see, I won't use any huge electronically guzzling parts, since I will skip the solar panel/LED parts in this model for the sake of getting started and not waiting for parts to arrive. I am thinking about using a siphon for the return water trip and working on a fish feeder following the same format as my previous balance method. Just tested the pump and figured it worked with some pretty hilarious resorts, which means I have to clean up the bathroom mirror now image. Pictures to arrive soon as I can get the pump set up. I will be buying hydroton media and start working on a bacterial filter later... (As a sidenote just using hydroton for now probably will scratch that out later). If I can get enough time today, I will try to take pictures and maybe figure out how to use a doodle program to paste a design picture. Now that I know what type of plant I will use, I will start building. I might have to make the module with an arduino, but I hope I can figure out relay modules in SS by then.
  • m.ratcliffe
    m.ratcliffe over 11 years ago +1
    Yes I have a good cheap solution to that problem, Like most products you can get the same thing marketed to different markets with a massive price difference. I use a fridge active carbon filter, they…
    balearicdynamics over 11 years ago in reply to m.ratcliffe +1
    It is true Michael! A lot of times I buy the same thing on a different market with an incredible difference of price.
    e14 Contributor over 11 years ago in reply to m.ratcliffe
    TY for the fridge idea will definitely look into it, although I still might go for using dechlorinator chemicals(boo to the unaturals image ) . I am currently in my small model using hose tubing. Just finished the gravel and my timer is coming in tomorrow. Probably will right a blog post about it as soon as it looks like I actually did anything image
  • m.ratcliffe
    m.ratcliffe over 11 years ago in reply to balearicdynamics
    A sad but true fact.
    It is true Michael!
  • m.ratcliffe
    Yes I have a good cheap solution to that problem, Like most products you can get the same thing marketed to different markets with a massive price difference. I use a fridge active carbon filter, they will run you about £5. the slower you pull the water thru the filter the better it can do its job, I run mine at 1L/min and usually leave it in for a year.
    Another good point here is that you can use pneumatic fittings and 1/4" [check the inlet size for filter] pipe for the rest of your system, the fittings are cheap and will allow you to split off, mount to a wall etc.
    First hit on British ebay, you are sure to find cheaper with a little searching:
    http://www.ebay.co.uk/itm/2-x-In-Line-Fridge-Water-Filters-Compatible-with-Samsung-Daewoo-LG-etc-/251512455236?hash=item3a8f4f8044
    Also, Just check you do actually have chlorine in the water, here at my address we dont have it 80% of the time it is added at random times when something bad is found in the water supply.
    Thanks for the comment. Been real busy, so have been getting my relay to working. Dechlorinator filters are expensive, but I don't want to leave standing water out(mosquitoes)... Got any ideas?
