element14's The Ben Heck Show
Blog Episode 119: Ben Heck's Surface Mount Soldering Tips and Tricks Episode
  • Author Author: pchan
  • Date Created: 7 Feb 2014 3:46 PM Date Created
  • Views 959 views
  • Comments 5 comments
  • surface
  • heck's
  • tips
  • episode
  • and
  • 119:
  • soldering
  • tricks
  • mount
  • ben
  • tbhs_ep
pchan
pchan
7 Feb 2014
Ben Heck home page
All previous episodes
Ben's build kit
    e14 Contributor over 12 years ago in reply to colecago
    He made this oven onEpisode 116 as an upgrade of the one from way back inEpisode 36. I'm not sure why he went with a regular resistor based oven this time. I'd think the infrared oven he used then then would have made it easier to do double-sided SMT boards.
    For the rework portion of the build, wouldn't it have been easier to gloop some paste flux over the chip leads, then hit all the pins with the iron?
    Granted, you'd have to go back with some Isopropyl Alcohol, so it'd take the same amount of time in the end, but there'd be less overall heating on the board.
  • colecago
    colecago over 12 years ago in reply to carpetofstars
    Indeed it does have top and bottom.  I know someone that built one recently with just top and it heated unevenly and didn't have good results.  The oven was a $15 big lots oven that I bought off of craigslist.  There are a few threads on here that talk about the components and code.
  • carpetofstars
    carpetofstars over 12 years ago
    I have seen a lot of video tutorials on DIY surface mount, but this is the best I've seen.  So clear.  I was happy to learn about that source of solder paste with a needle injector.
    I presume your toaster oven must have both top and bottom heating elements (bake and broil).  Some only have bottom elements.
    The text mentioned frying pan soldering, but this might involve magnetism (magnetic inductance coils) that could destroy some components.
    shabaz over 12 years ago
    "Looking like it's connected doesn't mean it is" :-) So true.
