element14's The Ben Heck Show
Forum Viewer challenge: fixing the 'Blinking NES'
  • Subscribers 32 subscribers
  • Views 888 views
  • challenge
  • heck
  • ben
Hello Ben. I have a Nintendo Entertainment System (NES) and it gets kind of annoying when the game doesn't start and the screen just 'blinks'.
So, how do i fix this? I heard from my friend that it has something to do with some kind of area-coding chip or something, but i'm afraid to open my NES for nothing.
Thanks.
  • benheck
    benheck over 15 years ago +1
    The ultimate reason for this is the lockout chip. Upon boot, the one in the NES sychronizes with the one in the cart and then allows the game to run. So it's mostly the 4 signal pins for the lockout chip…
    You clean the 72 pin connector with rubbing alcohol and the game will always need jiggling for you to get it to work but it is fixable with rubbing alcohold and patience of moving the game and jiggling it and resetting once you get the right menu and it continues to reset hit the reset button, There's many methods to fix it just look up the NES 72Pin Connector problem for tutorials
    yes, I had to do this with my NES and still do
    Yeah. heard that before. the problem is that i'm sick of cleaning the connector over and over again...
    I'm looking for a permanent solution.
  • Kelv
    Kelv over 15 years ago in reply to e14 Contributor
    Sounds like another contender for the "road test" projects to me image
  • benheck
    So it's mostly the 4 signal pins for the lockout chip that get corroded and cause problems on the cartridge.
    You can elimate this pitfall by disabling the NES's lockout chip. Google "disable NES lockout chip" and you can locate instructions. It's super easy, the slowest part is opening the NES to get at it.
    You can also split the audio signals and separate some of the channels to left and right stereo (if you had some RCA jacks)
    e14 Contributor over 15 years ago in reply to benheck
    Thanks. Works fine now, just had to ground pin four or three...
  • jnrz81
    jnrz81 over 11 years ago
    I disabled the 10NES chip in my NES and it no longer blinks. But now I only get a green screen, whether there's a game in it or not. Help! What do I do?
