element14's The Ben Heck Show
Forum Challenge: Securing Pet door
  • Subscribers 32 subscribers
  • Views 546 views
  • build_challenge
  • Controllers
  • ben_heck
thecatsandi
thecatsandi over 14 years ago
Ben,
I have two cats. I have recently acquired three racoons.
The Racoons are coming through the cat door into my house.
I need to stop this
Some sort of motorized, RFID gizmo should work. I am not to the level where I could build this yet. Yet I need a solution quickly.
Please accept so I can live Racoon free. Shooting them is not an option since I live in city limits.
  • benheck
    benheck over 14 years ago +2
    Yeah perhaps RFID tags on their collars? Have to make sure the range is sufficient, since the scanner would be on the door, tag on the collar, so there's the distance of the length of the cat's head to…
  • evan.stoddard
    evan.stoddard over 14 years ago
    Yea, this is a great idea for a project.  It shouldn't be to hard for ben.  A lot of the stuff exists.  He just needs to find a build.  Ill help him out and give him a link to this. http://www.element14.com/community/docs/DOC-43401/l/avonwood--eur111k4907--kit-rfid-eureka-125khz-rs232-reader
  • benheck
    Yeah perhaps RFID tags on their collars? Have to make sure the range is sufficient, since the scanner would be on the door, tag on the collar, so there's the distance of the length of the cat's head to get past.
    This makes me think of my sister's fat huge cat, which actually looks like a raccoon!
    Could be a good project!
  • evan.stoddard
    evan.stoddard over 14 years ago in reply to benheck
    What if you had like a solid door and anything can get out put then have metal posts that go in and out and prevent the door from opening inward unless those posts are retracted.  When the rfid was authorized then those posts would retract and the door could open inward because nothing in blocking it.  It's inexpensive and easy to build.
  • thecatsandi
    thecatsandi over 14 years ago in reply to evan.stoddard
    I have noticed there are two frequencies that RFID operates. 125kHz and 13.56 MHz. For the same power, I can understand 125kHz for longer range. However, you need a larger antenna. For the 13.56MHz you get shorter range and a smaller antenna.
    Since my door to be secured is metal I would have to put the antenna on the outside. The cat door is centered and low. It is weather protected.
  • sqkybeaver
    sqkybeaver over 12 years ago
    perhaps an old lesson I was forced into will help you.
    I have lived far from the city for all of my life, have had many problems with all sorts of wildlife. the majority of them have been solved with non technology related solutions.
    I'd suggest humane traps, or lethal means. since at least one of these is not an option, the rfid collar is an good solution. beyond wiring it up the programming is nothing more than a simple "if, then" this should be easy. many open hardware vendors supply everything needed for an RFID solution, and some even have sample code you can copy and paste.
    an other option is Coyote urine. many smaller creatures will avoid it.
