Project Videos
  • Project Videos
Project Videos
Documents Build Inside The Box Challenge! -- Episode 500
  • Author Author: kellyhensen
  • Date Created: 20 May 2021 2:11 PM Date Created
  • Last Updated Last Updated: 28 May 2021 7:24 AM
  • Views 11419 views
  • Likes 15 likes
  • Comments 39 comments
Welcome to the 500th episode of element14 presents!  We decided to try something new for this episode - pitting three of our content creators against each other with the limitations of creating a working project with all of the parts in THE BOX.  We also challenged the community members with the same restriction - you can see their projects here.
James, Clem and Katie are competing in this challenge - but they're playing for their favorite STEM organizations.  See more about the competition.
Here's a link to the prizes the STEM organizations can win.
BONUS content:
Since we covered three builds in this episode, we thought you might like some more behind the scenes footage of each of the projects:
Katie's Digital Theremin
Clem's Parcel Calculator
James' Getting Sound out of an Arduino
Member's Entrants:
We also challenged our members to Build Inside The Box , click through to see the Member Projects! Also watch related episode 504.
And here's the Brainstorming Call where they discussed the parts when they received them.
Here's what's in THE BOX:
The BOX Buy the Box*
Arduino MKR Zero
Buy Now
MULTICOMP PRO Portable USB High Capacity Power Bank
Buy Now
WAGO Pluggable Terminal Block
Buy Now
Microchip Op Amp
MICROCHIP MCP604-I/P Operational Amplifier
Buy Now
Vishay Phototransmitor
VISHAY Phototransistor
Buy Now
MIDAS OLED Graphic Display
Buy Now
MICROCHIP Temperature Sensor IC
Buy Now
ST Microelectronics Gesture Sensor
ST Range/Gesture Sensor 53L0-SATEL-I1
Buy Now
element14 presents
Build Inside the Box
About the Challenge | What's In The Box | element14 presents | Project Videos | Member Challenge Winners | Episode 504
  • vishay
  • clem
  • microchip
  • arduino mkr zero
  • baldengineer
  • e14presents_mayermakes
  • 500_episode
  • e14presents_katiedumont
  • e14presents_baldengineer
  • build_inside_the_box
  • katie
  • james
  • friday release
  • multicomp
  • build inside the box
  • midas
  • wago
  • friday_release
  • bitb
  • cstanton
    cstanton over 5 years ago +8
    These projects are so good it's difficult to choose! I'm impressed as to how well everyone came up with ideas for the bunch of kit in the box I threw together, mwa hahaha!
  • cummns
    cummns over 5 years ago +7
    I wanted to make sure I put all the things I liked about each of the builds. While voting is great, I wanted to make sure everyone knew that they were all awesome builds! Great job! Clem's Parcel Measurer…
  • mayermakes
    mayermakes over 5 years ago in reply to cummns +3
    Thanks Keith! I actually plan to make another iteration on that project with Barcode reader addition and more selective parts for the buld to practicalyl use it on my little webshop. Honestly I Am in great…
  • easyejl
    easyejl over 5 years ago in reply to easyejl
    Hmm katie's project has got me back to thinking about the "theramin" as it was something I had considered initially. I've now come up with a really rube goldberg idea around it. imagine the 2 TOF sensors each mounted on either a belt setup or threaded rod, so they're capable of moving, one on the x axis, one on the Z. the steppers would use the reading from the sensor on the X axis to set the height of the Z axis, and vice versa. so long as they were fast enough, it would track your hand in the air, and so you could control whichever 2 of parameters you'd want at the same time, say for instance frequency and volume. Hmm, I may go ahead and try doing that, I do have the spare nema 17s laying around.
  • easyejl
    Dang, it is really difficult to decide. Clem's is practical and real world, Katie's is really creative (and she used the box), and James' is both creative and polished. I really liked James' idea of using the phototransistor as a punch card reader (even though that's not how it ended up), the idea had not crossed my mind. Excellent work from everyone!
  • johntk256
    johntk256 over 5 years ago in reply to hifromkatie
    That's great, thanks for the info Katie, I'll give that a try :-)
  • zaidali87
    zaidali87 over 5 years ago
    Cool builds, Katie has it all, stuck to her initial plan, creative idea, and she is literally used all the components inside the box including the box itself  image
  • hifromkatie
    hifromkatie over 5 years ago in reply to cummns
    Thanks, thats a lovely round-up of the projects. I was going for the fun aspect, I'm hoping that when the group I'm competing for has events again that it'll be something I can take along for the kids to play with.
  • hifromkatie
    hifromkatie over 5 years ago in reply to johntk256
    I used what I had on my bench which was, a 12ohm 25W power resistor (https://uk.farnell.com/cgs-te-connectivity/hsa2512rj/resistor-alu-housed-12r-5-25w/dp/2009315 this exact one)
    I put it directly between gnd and the 5v pad on the arduino.
    It's a fairly crude solution, but works.
  • cstanton
    cstanton over 5 years ago in reply to baldengineer
    Wildcard.
  • kmikemoo
    kmikemoo over 5 years ago in reply to baldengineer
    baldengineer  Yes.  It was great fun.  Build Inside The Box - Sump Pump Alarm
    Between you and Katie, now I have to make my Arduino make sound.  Thanks for the bonus content on how to make that happen.  I'll be using it.
  • kmikemoo
    kmikemoo over 5 years ago in reply to johntk256
    johntk256  You'll need a periodic draw of around 100mA to keep the power bank awake.  50Ω, 1/2w gets you there.  As you can tell, Katie went with a bit more robust resistor.  Check out John Wiltrout's (jw0752 post.  You may find his device useful.
    On Using a USB Battery for a Portable Project Power Supply
  • baldengineer
    baldengineer over 5 years ago in reply to kmikemoo
    Thanks Mike. Awesome members like you help keep me, and I suspect the others, motivated to create stuff for the community!
    Didn't you do a project with the parts?
