Project Videos
  • Project Videos
Project Videos
Documents How to Build a Quadruped Robot - NO MATH! -- Episode 538
  • Date Created: 15 Feb 2022 2:44 PM Date Created
  • Last Updated Last Updated: 18 Feb 2022 8:24 AM
  • Views 17014 views
  • Comments 15 comments
What is better than a wheeled robot? One with legs! But usually when building Hexapods and Quadruped robots, you need to deal with a lot of complicated math and inverse kinematics! Clem ventures out to make a quadruped robot without having to do complicated math!
The evolution of this project:
Episode 489: Build an FPV Rover with Raspberry Pi
Episode 508: Raspberry Pi FPV Rover Easy Robot Arm Upgrade
Supplemental Material:
  • Resources
  • Episode 538: Bonus Content: Code
Bill of Material:
CHIP QUIK Solder Flux CHIP QUIK 1 Buy Now
MULTICOMP PRO Servo Motor MULTICOMP PRO 1 Buy Now
MICROCHIP Fixed LDO Voltage Regulator MICROCHIP 2 Buy Now
DFROBOT Servo Motor DFROBOT 14 Buy Now
NXP LED Driver NXP 2 Buy Now
Additional Parts:
ESP32S2-Wroom MCU module
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • clem
  • robot
  • servos
  • robot project
  • friday_release
  • mayermakes
  • e14p_CMM
    beacon_dave over 4 years ago in reply to mayermakes +1
    Reinforcement learning ? let math do the math... Quadruped Robot Locomotion Using DDPG Agent https://uk.mathworks.com/help/reinforcement-learning/ug/quadruped-robot-locomotion-using-ddpg-gent.html
    DAB over 4 years ago +1
    Great project Clem. There are many ways to use 32 servos to improve the leg articulation and movement. That type of robot would be a major undertaking, so I think your simple solution is better for…
    beacon_dave over 4 years ago +1
    James Bruton did some robot dog projects. Not sure if anything in there might be of interest ? Mini Robot Dog https://www.youtube.com/watch?v=DfBF26DaT-M&list=PLpwJoq86vov_qzmadB1zj6aVKObH3WbeH openDog…
    dubbie over 4 years ago
    A great robot. The design of the legs looks interesting. I might have to have a closer look to see if there are any ideas I can borrow. I have had a number of goes at designing my own 3D printed walking robot, see photograph. I didn't get very far as I was still struggling with the 3D printer at the time, plus I wanted to minimise the number of servos - in my case to only 8. I've since given up on trying to minimise servos and use as many as I like with a PCA9685 16 channel PWM pcb (which works well) with a biped robot I am playing with.
    I did work out that if the four legged robot was square rather than oblong, then it is just about possible to balance of three legs freeing up the remaining leg to be moved forward. In this way the robot is able to 'walk' without having to ground the base. I did not quite manage to get it going as it all depended on where the centre of gravity is and I had not yet placed the batteries. I might have to return to it some time to see if I can do better.
    Dubbie
  • mayermakes
    mayermakes over 4 years ago in reply to dubbie
    well my design was based on ...nothing really I just winged it. A square overall shape would have been easier to work with in hinsight. the robot now tends to fall bawards on long steps.
    If I d do another one I'd put more time into the mechanical design from a theoretical base.
  • mayermakes
