Project Videos
  • Project Videos
Project Videos
Documents How to Build a Quadruped Robot - NO MATH! -- Episode 538
  • Date Created: 15 Feb 2022 2:44 PM Date Created
  • Last Updated Last Updated: 18 Feb 2022 8:24 AM
  • Views 16678 views
  • Comments 15 comments
What is better than a wheeled robot? One with legs! But usually when building Hexapods and Quadruped robots, you need to deal with a lot of complicated math and inverse kinematics! Clem ventures out to make a quadruped robot without having to do complicated math!
The evolution of this project:
Episode 489: Build an FPV Rover with Raspberry Pi
Episode 508: Raspberry Pi FPV Rover Easy Robot Arm Upgrade
Supplemental Material:
  • Resources
  • Episode 538: Bonus Content: Code
Bill of Material:
CHIP QUIK Solder Flux CHIP QUIK 1 Buy Now
MULTICOMP PRO Servo Motor MULTICOMP PRO 1 Buy Now
MICROCHIP Fixed LDO Voltage Regulator MICROCHIP 2 Buy Now
DFROBOT Servo Motor DFROBOT 14 Buy Now
NXP LED Driver NXP 2 Buy Now
Additional Parts:
ESP32S2-Wroom MCU module
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • clem
  • robot
  • servos
  • robot project
  • friday_release
  • mayermakes
  • e14p_CMM
    beacon_dave over 4 years ago in reply to mayermakes +1
    Reinforcement learning ? let math do the math... Quadruped Robot Locomotion Using DDPG Agent https://uk.mathworks.com/help/reinforcement-learning/ug/quadruped-robot-locomotion-using-ddpg-gent.html
    DAB over 4 years ago +1
    Great project Clem. There are many ways to use 32 servos to improve the leg articulation and movement. That type of robot would be a major undertaking, so I think your simple solution is better for…
    beacon_dave over 4 years ago +1
    James Bruton did some robot dog projects. Not sure if anything in there might be of interest ? Mini Robot Dog https://www.youtube.com/watch?v=DfBF26DaT-M&list=PLpwJoq86vov_qzmadB1zj6aVKObH3WbeH openDog…
    Great project Clem.
    That type of robot would be a major undertaking, so I think your simple solution is better for what you want to do.
    To improve stability, you could introduce an IMU chip that would give you sufficient feedback on all three axes to build a smoother control algorithm for movement.
    Given the calculations, you would probably have a slow moving robot, but it would be a better platform for adding your camera.
  • mayermakes
    mayermakes over 4 years ago in reply to DAB
    that is indeed true, I might build another version in the future, based on community feedback.
    Have you seen the robot dog projects on James Bruton's YouTube channel ?
    Tried to link to them yesterday but the spambot took a dislike to them.
  • mayermakes
    mayermakes over 4 years ago in reply to beacon_dave
    sure have! maybe Ill try a very coded version that works with compliant joints down the line.
