Project Videos
  • Project Videos
Project Videos
Documents A Noise-Free DIY Switching Power Supply - How Hard Can It Be? -- Episode 542
  • Date Created: 10 Mar 2022 5:22 PM Date Created
  • Last Updated Last Updated: 18 Mar 2022 8:24 AM
  • Views 13169 views
  • Likes 12 likes
  • Comments 14 comments
Switch Mode Power Supplies (SMPS) need a printed circuit board (PCB). To see why check out this video. We look at how hard could it be to get a PCB design right! Hint: You need copper zones to get a low-noise SMPS design.
Supplemental Content:
  • Free Routing
  • Workbench Wednesdays Measuring SMPS Ripple
  • Resources
Bill of Material:
DC/DC CONV, BUCK/BOOST/INVERT, 85DEG C On-Semi 1 Buy Now
Small Signal Schottky Diode, Single, 45 V, 8 A, 570 mV, 120 A, 150 °C Vishay 1 Buy Now
Power Inductor (SMD), 180 uH, 1.9 A, Shielded, 1.6 A, SRR1210 Series, 12mm x 12mm x 10mm Bourns 1 Buy Now
CAP, 4700uF, 16V, RADIAL, SMD PANASONIC 1 Buy Now
SMD Multilayer Ceramic Capacitor, 0.47 µF, 25 V, 0805 [2012 Metric], ± 10%, X7R, -55 °C SAMSUNG ELECTRO-MECHANICS 1 Buy Now
Surface Mount Thick Film Resistor, CRG Series, 68 kohm, 330 mW, - 5%, 150 V RoHS Compliant: Yes TE CONNECTIVITY 1 Buy Now
SMD Aluminum Electrolytic Capacitor, Radial Can - SMD, 330 µF, 25 V, 0.8 ohm, 2000 hours @ 85°C NIC COMPONENTS 1 Buy Now
Additional Parts:
PCBs: Auto-Routed, 6mil no pour, 6mil with ground pour, and Copper Zones
element14 presents
element14 presents  |  About James |  Project Videos
  • vishay
  • SMPS Design
  • On-Semi
  • buck converter
  • SAMSUNG ELECTRO-MECHANICS
  • smps
  • e14p_JBE
  • panasonic
  • te connectivity
  • james
  • SMPS PCB
  • bourns
  • pcb design
  • NIC COMPONENTS
  • friday_release
    dougw over 4 years ago in reply to kmikemoo +1
    I had an instructor that used the same phrase - I think in connection to report writing objectives. It seems to me the more I know the less obvious it becomes.
    dougw over 4 years ago +1
    Interesting episode, although designing for failure rubs me the wrong way. I would like to see to see if there is a difference between realistic attempts - I doubt anyone would design with a 6 mil trace…
  • mayermakes
    mayermakes over 4 years ago in reply to dougw +1
    I agree, a follow up episode showing how to impedance match traces and compare them to filled zones would be interesting!
  • kmikemoo
    kmikemoo over 4 years ago
    baldengineer  I don't know about the "easy" rating.  I once had an instructor that would say things were "intuitively obvious to the most casual observer" - but only once you knew the correct answer.  I really appreciate you taking the time to walk through the WHY behind you making the board the way you did.  Great stuff!  Very useful. Thumbsup
