Project Videos
  • Project Videos
Project Videos
Documents Using a Pi Pico to Convert Keyboard Input to Morse Code -- Episode 573
  • Author Author: cstanton
  • Date Created: 14 Oct 2022 12:51 PM Date Created
  • Last Updated Last Updated: 21 Oct 2022 7:24 AM
  • Views 151795 views
  • Likes 13 likes
  • Comments 51 comments
Ever fancied sending a message via Morse code, but the process of working out the dots and dashes seems daunting? Then why not make a keyboard that will convert the text you type into Morse code, in an audible and visual form!
Watch the Video
Supplemental Content:
  • Wiring and Code
Bill of Material:
RASPBERRY PI PICO W RASPBERRY-PI 1 Buy Now
RPI-KEYB (UK)-BLACK/GREY RASPBERRY-PI 1 Buy Now
PROJECTS UNLIMITED Transducer, 3 V to 28 V, Continuous, 90 dB, Sounder, 5 mA, Panel Mount PROJECTS UNLIMITED 1 Buy Now
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • how to use the pico as a keyboard
  • rpi pico
  • morse code
  • raspberry pi pico
  • raspberry pi
  • text to beeps
  • text to code
  • friday_release
  • scottiebabe
    scottiebabe over 3 years ago +1
  • scottiebabe
    scottiebabe over 3 years ago in reply to dougw +1
    If you were able to decode that with out computer aid, you deserve a prize! I cheated and used: https://morsecode.world/international/translator.html lol
  • hifromkatie
    hifromkatie over 3 years ago in reply to scottiebabe +1
    Thank you! Made me realise, I didn't add punctuation in my code, I'll add that when I get a chance.
  • scottiebabe
    dougw over 3 years ago in reply to scottiebabe
    It took a minute for me to get this...Relaxed
  • scottiebabe
    If you were able to decode that with out computer aid, you deserve a prize! Confetti ball
    I mean it took me a minute just to figure out that it was Morse code. Initially I thought it was a line of text where only 2 rows of pixels were displayed. I had to select/highlight it to realize what it was. Relaxed
    Here's an attempt with emoticons: Black circle Heavy minus sign     Black circle Heavy minus sign Heavy minus sign      Black circle      Black circle Black circle Black circle       Heavy minus sign Heavy minus sign Heavy minus sign        Heavy minus sign Heavy minus sign
    beacon_dave over 3 years ago in reply to dougw
    "...Initially I thought it was a line of text where only 2 rows of pixels were displayed..."
    Time to replace the ribbon on your DECwriter terminal?   Slight smile
  • scottiebabe
    Yes your method is much more human readable, but harder to copy into a web translator lol Slight smile
    I can't read it either way. I just went down a rabbit hole looking for an "easy" alternative - with mixed results. Relaxed
  • scottiebabe
    I'm tempted to put a LM567 (PLL tone detector) into a breadboard and try to go from beeps to text...
    Cool idea. I've wanted to make a Morse decoder since before I had a bucket list. I have a couple of short wave radios that still pick up Morse code in action.
  • hifromkatie
    hifromkatie over 3 years ago in reply to dougw
    I hadn't thought about being able to pick it up on a short wave radio, that makes me tempted to try picking it up and decoding it as another project
    beacon_dave over 3 years ago in reply to hifromkatie
    You might want to look at RTTY (radio teletype) as well then. Baudot-Murray code over the radio.
    I recall in the 80's a student doing this on a ZX81 with his amateur radio.
    For a STEM activity you could perhaps try to use LORA to communicate over longer distances.
    dougw over 3 years ago in reply to hifromkatie
    Morse code decoding can get a bit tricky since all timings are variables and they all have a significant tolerance. It would likely make a good ML or AI application, although it can be done with just rules, ratios and tolerances.
  • hifromkatie
    hifromkatie over 3 years ago in reply to beacon_dave
    Interesting, I've been trying to think of a project to incorporate LORA as I've not done much with it before
  • hifromkatie
    Yes, the timings aren't designated for morse, the gaps etc are given in terms of time of beeps. but no duty frequency, I experimented and just picked what sounded nice for listening too
