Project Videos
  • Project Videos
Project Videos
Documents DIY Open Source Bluetooth Headphones -- Episode 586
  • Date Created: 17 Jan 2023 3:59 PM Date Created
  • Last Updated Last Updated: 20 Jan 2023 8:24 AM
  • Views 37426 views
  • Comments 41 comments
Dodgy apps, subscription fees, and exclusive phone apps for a pair of headphones? Clem says: no thanks! He's fed up with the shenanigans some manufacturers pull for simple products that should just work. And why change to a different model of headphones when you've found the perfect wired pair? Can't you have that same fit and style, but wireless? So, for this project, Clem sets out to add Bluetooth to some of his favorite wired AKG headphones, using a DFRobot FireBeetle and an I2S audio module. But, to be a true open-source alternative, Clem has to whip up a custom PCB, which doesn't go according to plan. Learn the pitfalls of overly similar part numbers by following his process of figuring out the problem! What Device should have an open source variant in your opinion and would you build it yourself?
Watch the Video:
Bonus Content:
  • Download All CAD and Code for Free!
Bill of Material:
DF robot firebeetle Esp32 DFROBOT 1 Buy Now
Additional Parts:
PCM5100 i2s module
Your favourite wired headphones
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • DFrobot Firebeetle
  • Bluetooth Headphones
  • diy
  • e14_CMM
  • open source
  • I2S audio module
  • friday_release
    beacon_dave over 3 years ago +1
    This was another interesting element14 presents project. Up until now I've been using the likes of Denon or Radial Engineering Bluetooth receivers: https://www.denonpro.com/products/view/dn-200br …
    https://www.radialeng.com/product/bt-pro
    to accommodate those pesky mobile device users... Starts to get expensive when you need to pair with multiple devices.
    However, this open-source project looks like this could open up some alternatives and experimentation.
    USB Audio 'Class Compliant' interfaces would be another interesting area to explore further. It would be great to have some 'problem-solving' adapters that can plug into a computer USB port without needing additional drivers and provide basic channel mixing / splitting type functionality along with basic level control and metering, ideally all within the limited USB power budget to avoid the need for yet another wall wart power supply.
  • mayermakes
    mayermakes over 3 years ago in reply to beacon_dave
    that sounds indeed like a neat problem solving product! would be cool to elaborate on that.
    beacon_dave over 3 years ago in reply to mayermakes
    I was thinking along the lines of taking the basic functionality of a USB audio interface something along the lines of this:
    https://cpc.farnell.com/behringer/uca202/usb-audio-interface-2-in-2-out/dp/CS20448
    and enhancing it somewhat to make it more useful as a problem-solving tool.
    One scenario I'm faced with is that a lot more people are relying on Zoom / MS Teams for online meetings these days however, such systems often expect a 2ch stereo USB based audio input/output whereas audio equipment is often still analogue based. Issues often encountered are:
    • no USB audio connectivity or USB audio connectivity but needs audio device drivers require installing but no admin rights to do so.
    • different analogue standards in use +4dBu on XLR vs -10dBV on RCA/phono so different levels and balanced / unbalanced signalling.
    • limited gain adjustment range at one or both ends.
    • mic level versus line level signals.
    • stereo vs mono.signals.
    • no visible level metering (is a signal actually present and if so, how hot is it?)
    So, you either tend to require an audio mixer with USB interface or end up with a number of problem-solving boxes and cables.
    A single problem-solving tool that can be simply plugged into the USB port and give you immediate indication if there is a signal present or not and at what sort of level and be able to configure it for mono/stereo operation and to be able to adjust the gains into the right ball-park and to deliver it on XLR or RCA/phono, all without needing to install drivers or a configuration app, would be a valuable tool.
    I've not seen anything available off-the-shelf that ticks all the boxes, without going over-the-top.
    Also, sometimes you want a problem-solving tool to use yourself and sometimes you want a problem-solving tool that you can mostly pre-configure and then hand to someone else and be able to support remotely over the phone.
    In an ideal world it might end up being an audio interface that has a bidirectional USB to I2S stage followed by a I2S DSP stage and then an analogue IO stage for maximum flexibility. However, to start off with I was thinking of something a bit simpler, basically an open-source USB audio interface with some basic signal mixing, level monitoring and gain control ability, all that can be powered off the USB port it is connected to.
    If it was a modular design, people could tailor it to their individual requirements e.g. balanced vs unbalanced outputs, different metering scales, different gain ranges etc. and even build their own custom mixer. I expect a number of people will be familiar with creating analogue audio circuits, but adding USB audio may be a bit new.
  • mayermakes
    oh yes that sounds very interesting, to solve the problems i actually have a fully fledged (small) audio mixer with USB interface.
    so its quite overkill and big to solve just me wanting to use normal audio gear instead of a dedicated USB microphone which I usually use.
    It basically was the reason apart from recommendations that I got a dedicated podcasting mic with USB.
    So the  key features are just controlling of levels and gain directly on the device, and instant working without drivers to install.
    I wonder if there are MCUS that can directly support WIn/mac/linux audo device types on native usb...
    A good DAC and ADC via I2S and a sturdy compact case would do the trick.
    Other key features are monitoring the signal levels visually, stereo<->mono routing, USB power, and low audio latency.
    To conserve power and save space, the monitoring could be a single LED 'bullet' meter which gets brighter as the input level increases. A bi-colour LED could be used to indicate nearing clipping of the USB input.
    The basic routing just needs the ability to mix the stereo LR output from the USB down to a mono output signal to send to the external analogue device and to take the mono return from the external analogue device and to send it to both the USB LR inputs. These should be individually selectable as you can often end up with a mono mic but stereo speakers type scenario.
    Not all computer sound drivers provide appropriate or reliable metering or routing functionality.
    Yes, I was wondering what MCUs might be able to do this as it would allow the ability to reconfigure the behaviour of the one hardware device in several ways and make it highly flexible.
  • mayermakes
    with all that I would be a bit worried of either the user interface having to many things to still be simple or with typical "one button designs" be cumbersome to use to get through all options quickly. it is a UX challenge as well.
    I thought about having two rows of adressable RGB leds, act as VU meter and indicator for settings.
    as long as you do nothing --> VU is show vor in/output
    When you move or click a rotary encoder, the leds indicate the setting to adjust. click to enter-> adjust ->click to exit.
    so GAIN in , Volume out, mono/Stereo in , mono/stereo out,
    Am I missing something?
    Speaking of USB mics, another problem-solver device waiting to be discovered is how to mix multiple USB mics down to a single USB mic. A number of web conference applications can only handle a single audio input device so if you have a presenter on a USB microphone and want to take a question from the audience or bring in a guest on another microphone, then you may have to reconfigure the audio input device in you web conference application and then reconfigure it back again. Being able to mix the 2 USB audio devices externally would be useful.
    There are a few USB audio type problems out there waiting for solutions.
    (Similar with USB web cams, I'm only aware of a single (expensive) product at the moment that allows you to switch between two USB webcams externally to the computer. If they are UVC class compliant webcams, then it should be possible to have a driverless solution.)
  • mayermakes
    oh thats is a whole different can of worms, but also a very interesting one.
    I think with a USB-Host capable MCU one could act as an intermediary to pass on only the data not the USb communications form the PC unlike a switch/hub.
    So the PC hosts an MCU via USB
    the MCU hosts 2 USB devices
    data from USb devices get pased on to the pc.
    the PC only ever sees 1 device, so for it its the same device that just passes on different data.
    the biggest challenge for that might be latency.
    Yes, that was intended as a separate project idea.  Slight smile
    ( The Inogenie devices do the webcam switching:
    https://inogeni.com/product/share2u/  )
  • mayermakes
    Seems the intended use is dunymic composition of additional sources into an hdmi feed, that is passed on downstream.
    yeah a simpler solution for just the mentioned usecase seems to fit aniche here!
    They do a 4:1 switcher 2xUSB/2xHDMI as well:
    https://inogeni.com/product/cam300/
  • mayermakes
    oh i just saw how expensive these devices are, well a simple solution just focused on the task would surely be abit more accessibly priced.
    That's one of the problem areas, most people can probably pull together a few low-cost USB devices, but when it comes to using several together, it can quickly become an overly complicated and expensive business.
  • mayermakes
    also making them all play nicely togethers and have no wonky conenctions is a cluttered desk in itself
    Another related USB project idea would be to intercept the control functions of a UVC compliant camera module in a USB pass-thru device. Quite often web conferencing applications will capture control of the USB webcam but then not give you any controls for adjusting focus, exposure etc. which can be annoying as often there isn't a separate control application for UVC devices. Being able to insert a pass-thru remote control into the USB cable, would quickly provide a solution.
    Take this one step further and it would be useful to be able to snoop and break the USB video stream out to a LCD display, at which point you now have yourself the basis for a low-cost USB 'studio camera'. Mount the camera onto a tripod and attach the LCD (touch)screen on a bracket and you have a preview of what the camera is framed on and easy access to the camera controls.
    One approach might be to use the likes of Arducam UVC compliant box cameras which have C-mount or S-mount lens options, allowing for a wide range of low-cost focal lengths and easy tripod mounting in a robust aluminium package. Alternatively, you could substitute any UVC compliant USB camera and 3D print some sort of mount for it if it doesn't already have one.
    Another approach might be to go down the R-Pi HQ camera route with its 7" touchscreen, however with on-going supply chain issues this may not be such a great option at present. I've seen a couple of UVC webcam projects done already this way but without the image preview screen.
  • mayermakes
    i think that is a great case for the new Arducam modules,
    with manual controlls over every aspect und pasing it on as UVC class Webcam feed t owhatever wants to use that feed.
    I have a couple of older Arducam box cameras and having to rely on Amcap to take them out of auto mode, lets them down.
    At the other end of the scale, I have a BirdDog PF120 'webcam' and it too is let down by the lack of access to manual controls when using it in USB mode.
