Project Videos
  • Project Videos
Project Videos
Documents Repairing a Neewer 660 Studio light - How Hard Can It Be? -- Episode 594
  • Date Created: 9 Mar 2023 2:01 AM Date Created
  • Last Updated Last Updated: 17 Mar 2023 8:24 AM
  • Views 24998 views
  • Likes 10 likes
  • Comments 46 comments
I’ve got a studio light which has suddenly become faulty, how hard could it be to fix it rather than replace? In today’s episode I try and fault find the PCB to see if its a fault I can fix.
Watch the Video:
Bill of Material:
8 bit MCU, STM8S003F3P6TR STMICROELECTRONICS 1 Buy Now
Fixed LDO Voltage Regulator HOLTEK 1 Buy Now
Pluggable Terminal Block WAGO 3 Buy Now
Additional Parts:
Fault studio light
element14 presents
element14 presents  |  About Katie Dumont |  Project Videos
  • fault finding
  • e14p_KD
  • neewar
  • Pluggable Voltage Regulator
  • 8 bit mcu
  • Fixed LDO Voltage Regulator
  • Studio Light
  • st
  • friday_release
  • led panel repair
  • hifromkatie
    hifromkatie over 3 years ago in reply to RichG +3
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver…
  • RichG
    RichG over 3 years ago +1
    Yes a new project with a microcontroller.
  • hifromkatie
    hifromkatie over 3 years ago in reply to dougw
    Yes, PWM to the LED driver circuits for each colour of LEDs. I had checked the lights independently and they are working fine, it's just the control that's dead, I think I may have ended up cutting that section of testing from the video, at one point it was an hour long fault finding episode!
    I tend to have both colours set to approx 50%, so wouldn't be that hard to wire up as fixed. Great suggestion, as I hadn't thought about that as a possibility, but it very rare that I change them.
  • hifromkatie
    hifromkatie over 3 years ago in reply to kmikemoo
    Not yet, life has been busy! I have some plans in my head though, for when I get to it :) Currently thinking 555 based control (well 556, theres 2 PWMs to be controlled independently).
  • hifromkatie
    hifromkatie over 3 years ago in reply to beacon_dave
    For some reason I honestly hadn't thought back to the fact I've got an identical unit, by that point it was mounted back above my desk!
    But trying to obtain the code off it is an interesting solution, although I suspect it might be read protected (I know all the products I've worked on in the past we have protected the microcontroller code).
    As far as I can tell the micro takes the potentiometer inputs and outputs a PWM for each pot, I haven't seem any other fuctionality, so I think it'd be interesting to replace it with a 555 based control circuit to either the original LED drivers, or just redo the drivers as well.
  • hifromkatie
    I'm quite tempted to go completely away from the original design and do a 555 based controller, the main operation of the micro was to take the potentiometer input and turn it in to a PWM to the LED driver side, which seems easily replaced by a 555 based circuit
    DAB over 3 years ago
    Nice walk through of the debug process.
    You could find a way to get the code, but what fun is that.
    Clearly you have a neat project to build a new controller.
    dougw over 3 years ago
    It is brave to video skills and techniques because everyone can comment on how to do it better. Don't let it stop you though. Hopefully everyone learns. One good test in a situation like this is a smell test - burn components usually smell burnt. It can narrow down the possibilities before a lot of disassembly. I doubt the fumes are healthy though.
  • michaelkellett
    michaelkellett over 3 years ago
    A thing to consider for the future. Did the processor fail and short out the regulator - or did the regulator fail and kill the processor. - we can't tell.
    WE don't have the full schematic but its certainly possible for regulators with small ceramic input caps to get overvolted by external supplies.
    See this Linear Technolgy App Note: https://www.analog.com/media/en/technical-documentation/application-notes/an88f.pdf
    While you are re-building you might like to mitigate against this effect if necessary.
    You could have a lot of fun actually testing the effect on your working lamp - but perhaps not such a good idea Slight smile
  • scottiebabe
    scottiebabe over 3 years ago in reply to beacon_dave
    Should have used a 7805/LM317, I'm sure that cheap CMOS LDO got up to no good when the 15V supply is plugged in.
    beacon_dave over 3 years ago in reply to scottiebabe
    Slight smile
    At first sight, the MCU appears a bit overkill for just dimming the LEDs. However perhaps they have just standardised on parts as some of the other models have to drive a small display screen.
    I was wondering what killed the MCU though. Did a failure in the driver dump 12v through the GPIO perhaps, which caused a short which killed the MCU regulator ? Quite often it is the LEDs that fail first as they are often pushed hard to get maximum light output. Chain reaction.
  • scottiebabe
    I know posting the same idea 4 minutes later makes me look like even more of a goof than usual! Face palm
    But yes, I would be interested to  know if the MCU is bringing anything interesting to the party. Or is it just doing basic telemetry to for overtemperature and battery SOC shutdown...
