Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15856 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • troles
    troles over 5 years ago
    Does this sketch use the "keyboard.h" library?  it refers to keyboard in many lines, but does not include this library in the sketch?  I am having trouble as it seems the sketch wants the keyboard library ?
  • maximocnc
    maximocnc over 5 years ago
    Hi folks. I'm new here, an I would like make my pendant but only have an arduino pro micro, I would want to ask you if you can pas me the schematic of the connections for it? or may be somebody have it?
    tnanks in advance to all.
    I'm at joseluis.cmax@gmail.com
  • mayermakes
    mayermakes over 5 years ago in reply to maximocnc
    Hi this project was done by mrvolt.
    if your Pro micro has a 32u4 MCU on it the keyboard library will work.
    if its a variant with 328p on you will need to use a different Board.
    the actual schematics dont matter that much, just connect your switsch between the pin you want to use for it and gnd. optionally place a pullup resistor on each pin or use the pinmode Pullup function in Code.
    (either way you need to make sure each pin is always at High OR low, never floating or in a weird state.)
    All the code does is wait for an input and output a corresponding keystroke  over the usb port.
  • maximocnc
    maximocnc over 5 years ago in reply to mayermakes
    Hi Clemens. I'm new here, an I would like make my pendant but only have an arduino pro micro, I would want to ask you if you can pas me the schematic of the connections for it? or may be somebody have it?
  • noahpurdy
    noahpurdy over 5 years ago in reply to timrod65
    I am having this same problem!
    I wonder if, from a code standpoint there is a way to simulate "holding" a direction push while the encoder is spinning vs. sending individual inputs. I'm a bad coder so, no bueno for me but it seems like rapidly sending a TON of inputs overwhelms Carbide Create.
    -N
  • azbrewer
    azbrewer over 6 years ago in reply to wildmack
    Another thank you, had same issue and that fixed it.
  • jgavin65
    jgavin65 over 6 years ago
    DJ - I have a working Pendant thanks to you!  I want to make the aluminum face place and need the CRV file to mill it.  Can you send it to me?
    Greatly appreciated!
  • wackyworm1968
    wackyworm1968 over 6 years ago
    Want to make one have no idea how to wire it.
  • timrod65
    timrod65 over 6 years ago
    On my Sahpeoko 3 encoder all buttons and led's work but button #4 or the fast button starts then stops
    says busy after a bit you can use all other buttons and encoder every time #4 same thing it's like the encoder
    is way to fast or a code setting to fast anyone have any ideas ?? The log shows this -> ? N0 G4P0 the ? is in
    a a black diamond
  • jgavin65
    OK, I've clearly missed the schematic for this project.  Can you send a link to it?  All of the parts will be here next week and the case is being made.
    Many thanks!
