Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15886 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • thomasvdd
    thomasvdd over 6 years ago
    I have made the project and can confirm that the original code runs just fine.
    The behavior you described is how it is intended to function, as you can see from the code:
    When pressing one of the speed buttons, the activespeed variable is being changed.
      if (buttonFast.fallingEdge()) {
        activeSpeed = SPD_FAST;
    The next time the loop() executes, the if statement triggers and presses a key (KEY_4)
    if (activeSpeed != lastSpeed){
        digitalWrite(lastSpeedLED, LOW);
        switch(activeSpeed){
          case SPD_FAST:
            Keyboard.press(KEY_4);
            Keyboard.release(KEY_4);
            digitalWrite(PIN_LED_FAST, HIGH);
            lastSpeedLED = PIN_LED_FAST;
          break;
    When pressing one of the X, Y, Z buttons, the activeAxis variable is being changed.
    (uncomment the serial print to verify if your button works)
      if (buttonX.fallingEdge()) {
        activeAxis = X_AXIS;
        //Serial.println("X");
    HOWEVER, the corresponding button (KEY_RIGHT) is ONLY being pressed when the encoder is turned.
    Pressing the X, Y or Z button only will NOT press any keyboard key.
      if (abs(newScrollPos - lastScrollPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
        if (newScrollPos - lastScrollPos > -1){ // positive increase
          switch(activeAxis){
          case X_AXIS:
            Keyboard.press(KEY_RIGHT);
            Keyboard.release(KEY_RIGHT);
          break;
    In conclusion: if your CNC doesn't move, your rotary encoder is probably badly connected.
    Check the connections from encoder to teensy (also the middle ground pin). If that fails, I would buy a new encoder and try again.
    Hope this helped
    Thomas
  • wildmack
    wildmack over 6 years ago in reply to thomasvdd
    Hello Thomas, thank you so much for helping me out with this, it's driving me nuts.   I bought 2 encoders, so I'll try changing them out today.  I checked the impedance on the encoder, and it changed as I rotated it, so I assumed it was working.  I used the three sided pins of the encoder, outer pin goes to pin 9 on the controller, the center pin is to ground, and the other outer pin is connected to pin 10 on the controller.   I opened the serial monitor and uncommitted the serial print line and each time I press the X,Y,X buttons it shows on the output of the serial monitor screen.  Should it repeat the X,Y,Z on the screen if I turn the encoder?   I'm still learning how to program, so this is way above my understanding.  Is there any way to see if the controller is actually sending the commands, like KEY_RIGHT?  I really need to get this working, so I really appreciate your help.  I just can't figure out what I'm doing wrong.  I have tried it on Easel, and Universal Gcode Sender, and my CNC doesn't move, but it moves if I use the up,down,left,right on my keyboard.
  • thomasvdd
    thomasvdd over 6 years ago in reply to wildmack
    Yeah, all keystrokes work since it simply emulates a keyboard.
    Hopefully the LC will work!
  • wildmack
    I'll let you know, after I try it.  Do you use yours on the  Shapeoko ?
  • thomasvdd
    No, I modified mine to run my Xcarve.
    But all keyboard commands are working for me (also arrow keys etc. )
  • wildmack
    OK, I'm trying to use this on the xPro V3 controller, which I think was used on some of the Xcarve machines.  Can you tell me the changes you made for it to work on your Xcarve, or share the sketch and let me try that?
  • wildmack
    I tried the Teensy LC and still no go.  I must be doing something wrong.  I'm following the pin connection per the sketch.  I ordered the Teensy 2 but I don't think it's the Teensy.  When I plug the Teensy in to the computer after I flash it, it says setting up keyboard, then comes back and says keyboard ready to use??
  • wildmack
    Thomas, any other ideas?
  • thomasvdd
    Strange... it has to be a problem in the code...
    It can't be the teensy, since the example sketch of the rotary encoder did work.
    Try changing:
      for (int ii = 2; ii < 11; ii++) pinMode(ii, INPUT_PULLUP);
    To:
      for (int ii = 2; ii < 9; ii++) pinMode(ii, INPUT_PULLUP);
    Otherwise, try starting with only the code related to the rotary encoder. If that works, you can start adding pieces of code bit by bit and see wheter it keeps working fine.
  • wildmack
    Thank you, Thank you, Thank you  Thomas, that was it.  Moves in X, Y, and Z as I turn the encoder.  The only thing that doesn't work is the speed, but I don't think there is a way to control the speed in Easel using the keyboard.  Now I just have to print the 3D models and carve and engrave the face plate.  Can't wait to get it done.  Thanks again.  Dave...............
  • thomasvdd
    Great!!! That really was my last hope :-D
    I don't use Eagle myself, so I don't know about the speed.
    I'm glad that it works in the end, have fun with it!
  • angryboy
    angryboy over 6 years ago in reply to thomasvdd
    thanks you, I had the same probleme and i've resolve him thanks you verry much
  • angryboy
