Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15871 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • timrod65
    timrod65 over 6 years ago
    On my Sahpeoko 3 encoder all buttons and led's work but button #4 or the fast button starts then stops
    says busy after a bit you can use all other buttons and encoder every time #4 same thing it's like the encoder
    is way to fast or a code setting to fast anyone have any ideas ?? The log shows this -> ? N0 G4P0 the ? is in
    a a black diamond
  • timrod65
    a a black diamond
  • noahpurdy
    noahpurdy over 5 years ago in reply to timrod65
    I am having this same problem!
    I wonder if, from a code standpoint there is a way to simulate "holding" a direction push while the encoder is spinning vs. sending individual inputs. I'm a bad coder so, no bueno for me but it seems like rapidly sending a TON of inputs overwhelms Carbide Create.
    -N
