Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15885 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • thomasvdd
    thomasvdd over 6 years ago in reply to wildmack
    Yeah, all keystrokes work since it simply emulates a keyboard.
    Hopefully the LC will work!
  • wildmack
    wildmack over 6 years ago in reply to thomasvdd
    That's what I did on the one I sent you.  I loaded everything on my surface pro.   I've been trying to change the program so it only has a KEY_RIGHT command to see if I could open a word document and turn the encoder and get the courser to move to the right when I turn it.  But I haven't figured out how to do it yet, I keep getting error messages when I try to verify.  I just bought the Teensy LC  maybe I'll try that and see if it works, I really don't want to have to buy another Teensy.  Have you tried to see if your's will move the courser in a document? If the computer just thinks it's another keyboard, shouldn't it move the courser around?
  • thomasvdd
    You could try to program the Teensy via another PC, preferably with a fresh install of Arduino IDE and the necessary libraries.
    If that fails, try a Teensy 2.0, which I am using. I don't have a Teensy 3.2 to test.
  • wildmack
    The file I sent is the original file.  I downloaded it right before I sent you the data.  Maybe I'm missing something on my pin inputs.  I connected everything to the sketch pin call out, but maybe there is something else that I'm not aware of.  Here are some pics of the Teensy pins that I'm using.  I only connected one ground wire and it's the same grounds that the encoder is connected to.  I do see there is another ground shown on the schematic but I didn't connect anything to it.  If the program ran fine for you, and if my pin connections look correct, the only thing I can think of is the Teensy isn't working correctly, but it was brand new.imageimageimageimage
  • thomasvdd
    I don't see any issues. Send me the exact file you are using right now, I'll take another look.
    Try downloading the original file again, maybe you accidentally changed something..
  • wildmack
    No, I just tried that small sketch and the Serial Monitor showed that the encoder was doing what it should.  Still don't know why my other sketch isn't working.  Do you see anything wrong in the output I provided?
  • thomasvdd
    So it's working then...?
  • wildmack
    /* Encoder Library - Basic Example
    * http://www.pjrc.com/teensy/td_libs_Encoder.html
    * This example code is in the public domain.
    #include <Encoder.h>
    // Change these two numbers to the pins connected to your encoder.
    //   Best Performance: both pins have interrupt capability
    //   Good Performance: only the first pin has interrupt capability
    //   Low Performance:  neither pin has interrupt capability
    Encoder myEnc(5, 6);
    //   avoid using pins with LEDs attached
    void setup() {
      Serial.begin(9600);
      Serial.println("Basic Encoder Test:");
    long oldPosition  = -999;
    void loop() {
      long newPosition = myEnc.read();
      if (newPosition != oldPosition) {
        oldPosition = newPosition;
        Serial.println(newPosition);
  • wildmack
    Hi Thomas, I ran this sketch and the encoder worked fine.  When I turned it to the left the counter went positive, and when I turned it to the right, it it started counting backwards to negative numbers.   ??
  • wildmack
    Finally got the file to copy.
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dave\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=keyboard,speed=96,opt=o2std,keys=en-us -ide-version=10811 -build-path C:\Users\Dave\AppData\Local\Temp\arduino_build_614201 -warnings=none -build-cache C:\Users\Dave\AppData\Local\Temp\arduino_cache_359151 -verbose C:\Users\Dave\Documents\Arduino\DH_CNC_Pendant\DH_CNC_Pendant.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dave\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=keyboard,speed=96,opt=o2std,keys=en-us -ide-version=10811 -build-path C:\Users\Dave\AppData\Local\Temp\arduino_build_614201 -warnings=none -build-cache C:\Users\Dave\AppData\Local\Temp\arduino_cache_359151 -verbose C:\Users\Dave\Documents\Arduino\DH_CNC_Pendant\DH_CNC_Pendant.ino
    Using board 'teensy31' from platform in folder: C:\Program
    Using core 'teensy3' from platform in folder: C:\Program
    Detecting libraries used...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp" -o nul
    Alternatives for Encoder.h: [Encoder-master@1.4.1]
    ResolveLibrary(Encoder.h)
      -> candidates: [Encoder-master@1.4.1]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp" -o nul
    Alternatives for Bounce.h: [Bounce]
    ResolveLibrary(Bounce.h)
      -> candidates: [Bounce]
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce\\Bounce.cpp" -o nul
    Generating function prototypes...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch/Arduino.h" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch/Arduino.h.gch"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp.o"
    Compiling libraries...
    Compiling library "Encoder-master"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master\\utility" "C:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master\\Encoder.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\libraries\\Encoder-master\\Encoder.cpp.o"
    Compiling library "Bounce"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Users\\Dave\\Documents\\Arduino\\libraries\\Encoder-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce\\Bounce.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\libraries\\Bounce\\Bounce.cpp.o"
    Compiling core...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\memcpy-armv7m.S" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\memcpy-armv7m.S.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\memset.S" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\memset.S.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\analog.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\analog.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\math_helper.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\math_helper.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\eeprom.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\eeprom.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\keylayouts.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\keylayouts.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\mk20dx128.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\mk20dx128.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\nonstd.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\nonstd.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\pins_teensy.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\pins_teensy.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\ser_print.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\ser_print.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial1.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial1.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial2.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial2.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial3.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial3.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial4.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial4.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial6.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial6.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial5.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial5.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\serial6_lpuart.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial6_lpuart.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\touch.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\touch.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_desc.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_desc.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_dev.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_dev.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_joystick.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_joystick.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_keyboard.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_keyboard.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mem.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mem.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_midi.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_midi.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mouse.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mouse.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_mtp.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mtp.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_rawhid.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_rawhid.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_seremu.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_seremu.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_serial.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_serial.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_touch.c" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_touch.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\AudioStream.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\AudioStream.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial1.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial1.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\DMAChannel.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\DMAChannel.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\EventResponder.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\EventResponder.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial2.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial2.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial3.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial3.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial4.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial4.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial5.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial5.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\HardwareSerial6.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial6.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\IPAddress.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\IPAddress.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\IntervalTimer.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\IntervalTimer.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\Print.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Print.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\Stream.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Stream.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\Tone.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Tone.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\WMath.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\WMath.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\WString.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\WString.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\avr_emulation.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\avr_emulation.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\main.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\new.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\new.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_audio.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_audio.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_flightsim.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_flightsim.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\usb_inst.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_inst.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=150 -DARDUINO=10811 -DARDUINO_TEENSY32 -DF_CPU=96000000 -DUSB_KEYBOARDONLY -DLAYOUT_US_ENGLISH "-IC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\yield.cpp" -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\yield.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\memcpy-armv7m.S.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\memset.S.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\analog.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\eeprom.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\keylayouts.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\math_helper.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\mk20dx128.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\nonstd.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\pins_teensy.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\ser_print.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial1.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial2.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial3.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial4.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial5.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial6.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\serial6_lpuart.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\touch.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_desc.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_dev.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_joystick.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_keyboard.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mem.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_midi.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mouse.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_mtp.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_rawhid.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_seremu.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_serial.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_touch.c.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\AudioStream.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\DMAChannel.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\EventResponder.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial1.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial2.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial3.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial4.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial5.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\HardwareSerial6.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\IPAddress.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\IntervalTimer.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Print.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Stream.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\Tone.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\WMath.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\WString.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\avr_emulation.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\main.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\new.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_audio.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_flightsim.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\usb_inst.cpp.o"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\core.a" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\core\\yield.cpp.o"
    Archiving built core (caching) in: C:\Users\Dave\AppData\Local\Temp\arduino_cache_359151\core\core_f48f851391ecdefeb7433529382701ac.a
    Linking everything together...
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1582023621 "-TC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3/mk20dx256.ld" -lstdc++ -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\sketch\\DH_CNC_Pendant.ino.cpp.o" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\libraries\\Encoder-master\\Encoder.cpp.o" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201\\libraries\\Bounce\\Bounce.cpp.o" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/core\\core.a" "-LC:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201" -larm_cortexM4l_math -lm
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.eep"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.hex"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.lst" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.sym" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf"
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/teensy_post_compile" -file=DH_CNC_Pendant.ino "-path=C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201" "-tools=C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/" -board=TEENSY32
    Using library Encoder-master at version 1.4.1 in folder: C:\Users\Dave\Documents\Arduino\libraries\Encoder-master
    Using library Bounce in folder: C:\Program Files
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "C:\\Users\\Dave\\AppData\\Local\\Temp\\arduino_build_614201/DH_CNC_Pendant.ino.elf"
    Sketch uses 16280 bytes (6%) of program storage space. Maximum is 262144 bytes.
    Global variables use 5584 bytes (8%) of dynamic memory, leaving 59952 bytes for local variables. Maximum is 65536 bytes.
    C:\Program Files (x86)\Arduino\hardware\teensy/../tools/teensy_post_compile -file=DH_CNC_Pendant.ino -path=C:\Users\Dave\AppData\Local\Temp\arduino_build_614201 -tools=C:\Program Files (x86)\Arduino\hardware\teensy/../tools -board=TEENSY32 -reboot -port=COM5 -portlabel=(null) -portprotocol=(null)
