Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15903 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • thomasvdd
    thomasvdd over 6 years ago in reply to wildmack
    Print screens are also fine for me. Put them together in paint for example
  • wildmack
    wildmack over 6 years ago in reply to thomasvdd
    Hi Thomas, I can't figure out how to copy and paste that data, is there a trick to it?  Dave........................
  • thomasvdd
    Don't think so, I already checked the differences and none are major dealbreakers.
  • thomasvdd
    When did you get the
    "ENC A HIGH TRIGGERED" and
    "ENC B HIGH TRIGGERED" ?
    If that happens when the encoder is turned, the encoder is connected correctly.
    In that case, the problem lies with the encoder library.
    I would like to see the output of this window when compiling and uploading. All of it image
  • wildmack
    Hi Thomas, could the pin configuration between the Teensy 3.2 and LC cause the issue?
  • wildmack
    Don't give up on me LOL
    OK, I put the text after this:
    long newScrollPos = encoderScroll.read();
    I don't see what checking the two boxes did?
    Here are the screen shots, it changed based on turning the encoder.  But, it was always printing something even when I wasn't pushing a button or turning the encoder??
  • thomasvdd
    I'm running out of ideas...
    Include those lines and upload of picture of the serial monitor when turning the encoder:
      if (digitalRead(PIN_ENC_A) == LOW){
         Serial.println("ENC A LOW TRIGGERED");
      if (digitalRead(PIN_ENC_A) == HIGH){
         Serial.println("ENC A HIGH TRIGGERED");
      if (digitalRead(PIN_ENC_B) == LOW){
         Serial.println("ENC B LOW TRIGGERED");
      if (digitalRead(PIN_ENC_B) == HIGH){
         Serial.println("ENC B HIGH TRIGGERED");
    Also, in File>Preferences, enable these settings:
    Share a screenshot of the output.
  • wildmack
    Nope, still no change??
  • thomasvdd
    The Serial.begin(9600); is needed for the serial monitor, just leave it uncommented.
    Since nor the buttons, nor the encoder trigger the encoderScroll.read(); function, I suspect you might be using the wrong library.
    This is the one I am using: https://github.com/PaulStoffregen/Encoder
    Normally, Arduino stores the libraries under Document/libraries/
    Remove all existing encoder libraries from this folder (if any) and replace with the one from the link above.
  • wildmack
    OK, connected the two buttons and add the code.  It sends out a continuous series of zeros to the right.  Nothing changes if I ground pins 9 or 10.  I used the same encoder as the one in the project from Element14  Attached are the specs.
    Just seems like it's not reaching the keyboard commands.  It's a brand new teensy, but I guess it could be bad, but even changing the pin assignments I get the same results.  In the program, should the  //Serial.begin(9600);  not be commented out?  I did change it, but got the same results.   ???
    for (int ii = 2; ii < 11; ii++) pinMode(ii, INPUT_PULLUP);
      for (int ii = 14; ii < 21; ii++) pinMode(ii, OUTPUT);
      digitalWrite(PIN_LED_X, HIGH);
      digitalWrite(PIN_LED_FAST, HIGH);
