Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15949 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • mayermakes
    mayermakes over 6 years ago in reply to wildmack
    the error says that it tries to load the Servo.h library, but my code version does not ask for that library at all.
    it refers to this File,  C:\Users\Dave\Documents\Arduino\DH_CNC_Pendant\DH_CNC_Pendant.ino:1:
    which is NOT what you got from me:
    the correct file is named:
    DH_CNC_PendantAxisR.ino
    in it Servo.h is not used at all.
    You must have loaded a different sketch.
    make sure that the Version downloaded form my github is loaded and try again.
  • wildmack
    wildmack over 6 years ago in reply to mayermakes
    Wow, I must have loaded the wrong file yesterday.  It was a keystroke program that ran perfect, but thats all it did.  I opened your file, and I see it does include the encoder.  I just tried to load it, but I get this message
    In file included from C:\Users\Dave\Documents\Arduino\libraries\Teensy_3X_Multipurpose_Board/Teensy_3X_Multipurpose_Board.h:2:0,
                     from C:\Users\Dave\Documents\Arduino\DH_CNC_Pendant\DH_CNC_Pendant.ino:1:
    C:\Users\Dave\Documents\Arduino\libraries\Servo\src/Servo.h:77:2: error: #error "This library only supports boards with an AVR, SAM, SAMD, NRF52 or STM32F4 processor."
    Multiple libraries were found for "Servo.h"
    Used: C:\Users\Dave\Documents\Arduino\libraries\Servo
    Not used: C:\Program
    Error compiling for board Teensy 3.2 / 3.1.
    I can't figure out why it won't load.  I bought the same encoder that's listed in the project, and I did try holding the buttons down while turning the encoder, but still didn't work.  Do you see why the program won't load for me?   Thanks Dave.....
  • mayermakes
    the encoder is included in my file:
    long newScrollPos = encoderScroll.read();
      if (abs(newScrollPos - lastScrollPos) >= 4) { // there are roughly four presses detected from each rotation to the next detent
        if (newScrollPos - lastScrollPos > -1){ // positive increase
    but these values refer to DJs specific encoder, so you might have to change these to fit your particular encoder.
    in theory this should work on any encoder that behaves the same, your encoder might differ, but you have allready checked that iirc.
    Also did you try pressing the button and scrolling at the same time?
    the code suggests that you may need to hold the axis button while scrolling to send the spoecific keystroke
  • wildmack
    No, the original file included the encoder which would let me keep sending the keystroke that was selected.  The file you sent only had the keystroke part, it didn't include the encoder.
  • mayermakes
    Well if the one I sent you runs fine, does this solve your problem?
    or is there still an issue?
  • wildmack
    The code you sent me runs fine.  The purpose of the other code was for it to pick a key stroke to send to the computer, then when you turn the encoder it would keep sending that keystroke.  I changed your code to try the up, down, right, and left and it ran fine.  There must be something in the other code that is working right, but I don't have enough knowledge to understand what all the code is doing.  I only know what it should do.
  • wildmack
    wildmack over 6 years ago in reply to baldengineer
    Doesn't show anything on the on-screen keyboard, nor does my regular keyboard?    The only thing showing activity on the on screen are keys like shift, cap locks alt etc..........
  • baldengineer
    baldengineer over 6 years ago
    Instead of Notepad, open the on-screen keyboard. It will show what keys are being pressed on any connected keyboard.
  • mayermakes
    as it is not my project I haven run the code, but the principle is the same no matter if you use an arduino or teensy.
    I have no teensy to try it out, but looking at the code if ound that the vars X_AXIS, Y_AXIS,Z_AXIS, might be mistaken for statements that belong to a different library as it is marked blue in my IDE.
    I changed it to a different name X_axisr..and so on.
    the code is here, rest is unchanged from the code provided by DJ.
    try it and let me know.
  • wildmack
    I'm getting output from the 4 speed buttons, but nothing from the X, Y, and Z buttons.  Per the program when the X button is pushed it should execute a KEY_RIGHT.  When the Y button is pushed it should execute a KEY_UP, and when the Z button is pushed it should execute KEY_PAGE_UP.    I'm not getting any output from these, I changed the KEY_RIGHT to KEY_7, the KEY_UP to 8, and the KEY_PAGE_UP to 9.  But, still nothing on the screen.  I checked the encoder, and it is changing from high to low state when it's turned.  I rechecked the pin connections and all check out.  Have you ever ran this program?
