Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15950 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • mayermakes
    mayermakes over 6 years ago
    Possibly they are sending non printable characters, get in the code and change the chars to abcd for example, if you still get nothing the issue is maybe in the wiring. The encoders need a ground referee nce. It has to be the same gnd as the mcu has. Use a multimeter to check if the pis really go low when you turn the encoders
  • wildmack
    wildmack over 6 years ago
    Anybody have any ideas.  I have the circuit built on a breadboard, but can't seem to figure out what I have done wrong.  I don't get any movement when I turn the encoder.  I only have two wires connected to the encoder to the A and B terminals.  I tried connecting the common to ground, but still no good.  Also, I have the keyboard set to the USB serial, mouse, keyboard and joystick.  I have double checked all the pins.   To try and see whit it was sending to the computer, I open up notepad and push the PIN_BTN_001MM it prints 1 on the screen.  When I push the PIN_BTN_01MM it prints 2.  When I press the PIN_BTN_1MM it prints 3. When I press the PIN_BTN_FAST it prints 4.  The PIN_BTH X,Y,and Z don't do anything.
  • mayermakes
    mayermakes over 6 years ago in reply to cmspooner
    as far as I can tell the MCU board used in this project has built in pullups, you ca nactivate themn in software.
    if you use an arduino micro for this (as I would) it has internal pullups for sure(also to be activated in code)
  • cmspooner
    cmspooner over 6 years ago in reply to rogo
    I agree. I am building one and was hoping to see if the button debounce was using internal pull-ups or not.
    I have the buttons and have assembled the top case. Electronics and programming today/early next week and then the bottom printed last.
  • e14phil
    e14phil over 7 years ago
    Now I want a home CNC...
  • rogo
    Nice build.
  • thomasvdd
