Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17890 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • jap1906
    Hi Guys,
    I'm thinking about start my first raspberry pi project with this task organizer.
    Two questions, that maybe are silly but I really don't know anything about raspberries
    1) Is it possible to integrate somehow a ETA module here? I'm gonna use the task organizer in my office and it would be GREAT if I could have a ETA to home, based on traffic from google maps
    2) Is it possible to build this in a raspberry pi zero w, or it must be the 3B+?
    Also, since I do not have a 3D printer, I'm thinking about doing this in a mdf stand with a compariment for the raspberry (that's why i'm wonderign about the Zero W since it's much smaller)
    Thank you!
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to jap1906
    Hi Joao,
    A zero can be used, the 3B was available to me so I went with that.
  • KalebTheMaker
    Hi Joao,
  • jap1906
    jap1906 over 6 years ago in reply to KalebTheMaker
    Thanks Kaleb!
    I'm having some issues in this process...
    I'm doing it with a new Raspberry Pi 4B, and in the pip install -r requirements.txt install, it says:
    "Collecting spidev==3.3 (from -r requirements.txt (line 85))
    Could not find a version that satisfies the requirement spidev==3.3 (from -r requirements.txt (line 85)) (from versions: 2.0, 3.0, 3.1, 3.2, 3.4)
    No matching distribution found for spidev==3.3 (from -r requirements.txt (line 85))"
    Should I change the requirements file?
    Thanks
  • jap1906
    Actually I change the spidev==3.3 to spidev==3.2 in the requirement.txt, followed all the instructions but when I run the infowindow.py I get the error:
    EXCEPTION IN PROGRAM ==================================
    'ascii' codec can't encode character u'\xe7' in position 6: ordinal not in range(128)
    <type 'exceptions.UnicodeEncodeError'>
    <traceback object at 0xb54bae68>
    END EXCEPTION =========================================
    DEBUG:root:DRIVER: ENTERING FOR LOOP
    DEBUG:root:SENDING DISPLAY_REFRESH COMMAND
    DEBUG:root:DELAY 100 MS
    DEBUG:root:WAIT UNTIL IDLE
    Do you know why is this happening?
    Thanks
  • clem57
    clem57 over 6 years ago in reply to jap1906
    Thanks
    The routine expect valid ascii below 128x and recieived e7x. Most problem like this implies the sender did not encode before sending data!
    Clem
  • KalebTheMaker
    Where are your to-do's coming from, and are you sure that is where this error is originating?
    And good on changing the requirements to meet your specific need.
    -Kaleb
