Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17202 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • morningshane
    morningshane over 5 years ago
    not sure if anyone can help me here with the error below
    INFO:root:Configuration Complete
    DEBUG:root:Todo API: TODOIST
    EXCEPTION IN PROGRAM ==================================
    'module' object has no attribute 'TodoistAPI'
    <type 'exceptions.AttributeError'>
    <traceback object at 0xb557d5f8>
    END EXCEPTION =========================================
    DEBUG:root:DRIVER: ENTERING FOR LOOP
    ^CError in sys.excepthook:
    Traceback (most recent call last):
      File "infowindow.py", line 51, in HandleException
        iw.display(rotation)
      File "/home/pi/1y/mod_infowindow/infowindow.py", line 80, in display
        self.epd.display_frame(self.epd.get_frame_buffer(self.image))
      File "/home/pi/1y/driver/epd7in5b.py", line 196, in display_frame
        self.send_data(temp2)
      File "/home/pi/1y/driver/epd7in5b.py", line 102, in send_data
        epdif.spi_transfer([data])
      File "/home/pi/1y/driver/epdif.py", line 50, in spi_transfer
        SPI.writebytes(data)
    KeyboardInterrupt
    Original exception was:
      File "infowindow.py", line 176, in <module>
        main()
      File "infowindow.py", line 58, in main
        todo = modTodo.ToDo(todo_opts)
      File "/home/pi/1y/mod_todo/mod_todoist.py", line 8, in __init__
        self.api = todoist.TodoistAPI(opts['api_key'])
    AttributeError: 'module' object has no attribute 'TodoistAPI'
  • morningshane
    KeyboardInterrupt
        main()
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to morningshane
    Hi Chen,
    Do you have the Todoist api stuff setup? Its possible that the module may fail to load if that opts['api_key'] does not exist for todoist.
    -Kaleb
