Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17912 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • baldengineer
    baldengineer over 6 years ago
    Awesome display for a great looking project. Thank you for sharing Kaleb.
    This idea looks great for the home automation project I'm planning.
  • baldengineer
    beacon_dave over 6 years ago in reply to baldengineer
    "...This idea looks great for the home automation project I'm planning...."
    Some of the smart HMI display modules from the likes of 4D Systems may be worth a look for home automation applications as well.
    https://4dsystems.com.au/products/4d-intelligent-hmi-display-modules
    They appear to do Arduino, BeagleBone Black, and Raspberry Pi pin-out versions.
    Farnell currently appear to stock some of the basic panels. The intelligent modules however can offer a highly graphical display option when used alongside a microcontroller type application, or offload the graphics if used with a SBC.
    I've been looking at these sort of display modules for room-based automation where I want to be able to add a highly customisable graphical control panel to allow preset recall, level adjustment, and metering from audio DSP processors avoiding the need to run application software on a connected PC or tablet device. The audio DSP processor just needs to be sent a rather limited set of control strings from the room control panel and the panel just needs to listen for level changes to update meters and status indicators. Unfortunately, the 4D Systems modules appear to lack wired Ethernet option which is fine for preset recall but would limit the achievable metering update rates over serial UART.
    Amulet Technologies produce similar style smart HMI display modules
    Amulet Technologies - Smart Displays
    Any community members actively using these type of displays over say a SBC with HDMI display ?
