Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17890 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to jimmybiscuit
    Of course!
    Thats the right link, following the directions for that will generate a .json file. That file needs to be loaded on to the raspberry pi in the /home/pi/InfoWindow folder (or whereever you installed it). Should be called google_secret.json. In the config.json the "calendar" line should be null.
    After it is loaded, run python infowindow.py and it will walk you through a process to setup the secret file. If I remember correctly, it will give you a link, copy that, paste into a web browser, then another key will be generated in the web browser and you will need to enter that into the command line. I know its a pain, its not my process but googles.
    Good luck, let me know if you run into any other issues!
    -Kaleb
  • jimmybiscuit
    jimmybiscuit over 6 years ago in reply to KalebTheMaker
    Thanks for the answer!
    Im currently running Python 2.7.16 on a fresh raspbian OS. The only thing I installed are the requirements from your file.
    I have inserted my API keys for Todoist and Openweather but Im not quite sure what to insert into the calendar line? Do I have to insert an API key? I tried it with the google calendar API and had no luck...
    I have also tried quickstart.py from this website: https://developers.google.com/tasks/quickstart/python  and it worked/opened a webbrowser window.
    Thanks again for taking the time to help me!
  • KalebTheMaker
    Hi there,
    Did you setup the google auth stuff on their side? That was kind of a tough part. Check this link, there is a button that says, "Enable the google TASKS API".
    "python infoWindow.py" is the correct way to run it. What version of python are you running?
  • KalebTheMaker
    Hi Matt,
    I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the fast refresh, and my initial findings are for the smaller screens. There were no methods for that in the supplied driver from the vendor.
    About on call, that would be a good use for this! I did on-call for years and know the pains!
    Thanks,
    -Kaleb
  • jimmybiscuit
    Really great project, thank you for the idea!
    I tried to replicate it with your code and everything but Im running into a software issue and Im not quite sure how to fix it. I tried just getting into python with the command "python" and after that run your script via "import infowindow" and after a short while I get INFO:root:Configuration Complete and nothing more.
    How do you get to run the script manually to get the google auth stuff? Im more of a hardware guy...
    Just running the script via "python infowindow.py" gets me:
    INFO:mod_utils.mod_google_auth:Initializing Module: GoogleAuth
    EXCEPTION IN PROGRAM ==================================
    unsupported operand type(s) for +: 'instancemethod' and 'str'
    <type 'exceptions.TypeError'>
    <traceback object at 0xb55c6378>
    END EXCEPTION =========================================
    DEBUG:root:DRIVER: ENTERING FOR LOOP
    DEBUG:root:SENDING DISPLAY_REFRESH COMMAND
    DEBUG:root:DELAY 100 MS
    DEBUG:root:WAIT UNTIL IDLE
  • msebok
    msebok over 6 years ago
    Great project.
    One thought regarding the refresh. My ebook reader refreshes at each chapter, at each page it seems to just write to the screen again. it may get muddy after a couple text changes but may also limit the number of refreshes that happen. The only time I really get annoyed at the refresh is when I come to the reader after not having read for a while and the book cover stays in the background, which seems to require a manual refresh. But for normal reading it does not bother me to refresh every page. (also the refresh is quick just flashes the screen and your done I dont know if this is due to it being a purpose built machine or??..)
    I really hope you are able to limit the refresh or figure a way around it for your purposes.
    I was thinking another use for this project, for my purposes (I have an on call schedule for work) but to get a decent sized screen that would display an entire month (like a calendar does) is quite expensive. but would be ideal because it would really only need to refresh once a month.
  • KalebTheMaker
    Hi all,
    If you are looking for the code for this project, I will link it here, and it will be added to the description of this post soon!
    https://github.com/KalebClark/InfoWindow
    -Kaleb
  • danx327
    danx327 over 6 years ago in reply to KalebTheMaker
    Thank you very much! Keep up the awesome stuff!
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to skyhook
    Hi Marie, here is the link to the code on Github.
    Thanks!
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to danx327
    Sure do, its all on Github. Here is the link, and I will try to get it in the main description of the video as well.
