Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17879 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • jap1906
    jap1906 over 6 years ago in reply to KalebTheMaker
    Actually I change the spidev==3.3 to spidev==3.2 in the requirement.txt, followed all the instructions but when I run the infowindow.py I get the error:
    EXCEPTION IN PROGRAM ==================================
    'ascii' codec can't encode character u'\xe7' in position 6: ordinal not in range(128)
    <type 'exceptions.UnicodeEncodeError'>
    <traceback object at 0xb54bae68>
    END EXCEPTION =========================================
    DEBUG:root:DRIVER: ENTERING FOR LOOP
    DEBUG:root:SENDING DISPLAY_REFRESH COMMAND
    DEBUG:root:DELAY 100 MS
    DEBUG:root:WAIT UNTIL IDLE
    Do you know why is this happening?
    Thanks
  • jap1906
    Thanks Kaleb!
    I'm having some issues in this process...
    I'm doing it with a new Raspberry Pi 4B, and in the pip install -r requirements.txt install, it says:
    "Collecting spidev==3.3 (from -r requirements.txt (line 85))
    Could not find a version that satisfies the requirement spidev==3.3 (from -r requirements.txt (line 85)) (from versions: 2.0, 3.0, 3.1, 3.2, 3.4)
    No matching distribution found for spidev==3.3 (from -r requirements.txt (line 85))"
    Should I change the requirements file?
    Thanks
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to jap1906
    Hi Joao,
    A zero can be used, the 3B was available to me so I went with that.
  • jap1906
    Hi Shabaz,
    shabaz over 6 years ago in reply to jap1906
    Hi Joao,
    1. Yes that is possible, the general way to do such a thing is to search for an 'Application Programming Interface' (API), so in this case you'd google for 'Directions API Google Maps'. In short you'll need to have a Google account and request a key and then use that to send HTTP requests from your code. If you've never done that before, then it's worth spending some time studying and trying Python (spend at least a few weeks on it) because that's what you'll likely be using. There are courses, books, videos and lots of simple projects to learn this, it depends what way of learning you're most comfortable with. There's no real shortcut, but it's a valuable thing to learn because then you'll be able to connect to almost any API to do stuff or get information into your code.
    2. I think for this project a Pi zero W could be used, but the author will know more. If you don't need the extra interfaces, or the additional memory or speed, then the Pi Zero W is a substitute (the Zero W has a very old processor on it). For learning to code, you can use a Zero W but you might want a more 'normal' Pi, e.g. a Pi 3B+ or a Pi 4 (2GB) should be adequate and fast. Don't forget to get a power supply for it (any mobile phone charger is not guaranteed to be suitable, the Pi power supply has some slight electrical differences).
  • jap1906
    Hi Guys,
    I'm thinking about start my first raspberry pi project with this task organizer.
    Two questions, that maybe are silly but I really don't know anything about raspberries
    1) Is it possible to integrate somehow a ETA module here? I'm gonna use the task organizer in my office and it would be GREAT if I could have a ETA to home, based on traffic from google maps
    2) Is it possible to build this in a raspberry pi zero w, or it must be the 3B+?
    Also, since I do not have a 3D printer, I'm thinking about doing this in a mdf stand with a compariment for the raspberry (that's why i'm wonderign about the Zero W since it's much smaller)
    Thank you!
  • clem57
    clem57 over 6 years ago in reply to rrichey
    rrichey  wrote:
    I’m about to build my first Pi project and I want to build a “thing” that displays my daily schedule. But I want it to hang outside my office door so when my calendar says I’m “busy” it will display something of a Do No Disturb sign or a come in if my calendar shows I’m available. I’m plagued by people always interrupting my groove. I just wonder if there’s a way to this.    I like what he said at the beginning  about it being over engineered.    because the obvious solution is to go hang a DND sign on my door knob...but where’s the frustration I mean fun in that?
    What! You have a door on your office.
  • rrichey
    rrichey over 6 years ago
  • Workshopshed
    Workshopshed over 6 years ago in reply to KalebTheMaker
    That definately flashes a lot more than the small screen I used which could redraw in about 5s.
    These screens works with charged ink particles so as you said it needs to do a clear like an etchaset. First it needs to charge all those ink particles then attract and repel as per your image. The three colour ones are more complex with red being partially charged.
  • pchow98
    pchow98 over 6 years ago
    How to add a module to connect to Microsoft To Do?
    Thank you!
