Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35797 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • benaim
    One good project, it's one project that you can modify  image
    So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution image ( Best resolution and linerality )
    I changed too, the place of friction, rotated of 90°,  it's now near of chair , And much less twist on the support image
    And for finish, I put all electronic in the tube ( now in carbon ) image
    Here some pictures of my new collective and the idea of the new friction image
    • Vote Up +5 Vote Down
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to benaim
    That is awesome! Very well done!
    Great example of a second iteration through this project. Thank you for sharing Philippe! And please keep us up to date if you make more changes.
    -Kaleb
  • benaim
    Thanks to you Kaleb to help me to depass my limits  :-)
    I hope that my new post, decide many people to do more, and share mods here  ;-)
    Of course, I will send here, if this (your) project change...
  • LeoSchoonbroodt
    LeoSchoonbroodt over 4 years ago in reply to benaim
    Hi Benaim, just downloaded Kalebs Files and Arduino program for the Collective and was indeed also wondering why not using a Hall element.
    See that you changed it to a Hall element instead of rotary encoders.
    Would you be so kind to share your 3D files and Arduino program with me?
    I never have done 3D design So that's a hurdle for me if i have to find out myself, i have bought an 3D printer for this project but don't have the 3d files for your implementation.
    Arduino programming will not be a problem but as you must have the file also, that would also be very appreciated.
    Thanks, Leo
  • LeoSchoonbroodt
    Thanks, Leo
