Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35933 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • fcaballerog
    fcaballerog over 6 years ago
    good morning how are you, I hope well, my name is Francisco and I am from Gran Canaria, Spain, first of all thank you for putting this magnificent project in everyone's hands since it is not easy to achieve something like this .. I have been watching the video and I have seen that you have made the STL files available to everyone, but what I cannot find is the electronics, the connection diagram of the arduino and the MCP 23017i GPIO with its components. Where could I get the electronic connection scheme? And my other question is, do you have plans to improve the project?
    Thank you.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to fcaballerog
    Hi Francisco,
    Apologies for the delay on a response, I have been busy with other projects! But I am going to try to check in on these from time to time.
    I did have a schematic, and the issue was that I tried new software when I made it which did not have any way to export it other than to Eagle format. And that is not very helpful for people without Eagle! I tried to figure out a way to export, but eventually just took a screenshot and uploaded it to the GitHub page (Linked above). I will also try to paste in this message.image
  • fcaballerog
    fcaballerog over 6 years ago in reply to KalebTheMaker
    Thank you! by the scheme I am looking forward to mounting it ..
    A question, is there any possibility to make a list of the components but to order them by aliexpress? I think it is the cheapest place for components ..
    Thank you so much..
  • nzcypher819
    nzcypher819 over 5 years ago in reply to KalebTheMaker
    Hi Kaleb,
    Any chance you could upload the Eagle schematic file please? Im going down the route of getting the board printed as my soldering skills are sub-par. Thanks in advance.
  • nzcypher819
    Hi Kaleb,
