Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35830 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
    e14 Contributor over 5 years ago
    Hi first of all thank you this is amazing.
    But I cant open the Base DXF File and cant find the Fusion files. Am I doing something wrong?
  • gtg938v
    gtg938v over 5 years ago in reply to e14 Contributor
    I submitted the file to Autodesk Customer Support and they said,
    "Thanks for the files you added to this support request. I have been able to reproduce the issue on my computer and also with several Autodesk software able to open FBX files. I can confirm that this file is corrupted."
    I'll let you know if they have any fixes on their end.
    In the mean time, Kaleb do you mind trying another upload of the fusion file? Maybe in a different file format?
    Thanks!
    Rich
