Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35830 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • kraythorne
    kraythorne over 5 years ago
    This looks like a great project, but where is everyone getting the CAD files from? The Fusion 360 link above seems to be view only?
  • gsjward
    gsjward over 5 years ago in reply to kraythorne
    https://www.element14.com/community/servlet/JiveServlet/download/94799-6-304639/HelicopterCollective_Resources.zip
  • kraythorne
    kraythorne over 5 years ago in reply to gsjward
    Hi Garreth
    Great thank you!
    Do you know if the fusion files are available anywhere?
    Regards
    Steve
  • benaim
    benaim over 5 years ago in reply to kraythorne
    When you see in 3D https://www.element14.com/community/external-link.jspa?url=https%3A%2F%2Fmyhub.autodesk360.com%2Fue2909875%2Fg%2Fshares%…
    You can download files
  • KalebTheMaker
    KalebTheMaker over 5 years ago in reply to kraythorne
    Hi Steve,
    Did you get all the files you needed?
    -Kaleb
  • kraythorne
    kraythorne over 5 years ago in reply to KalebTheMaker
    I can see the design in the fusion 360 page, but cannot work out how to download the fusion files - can you advise which buttons to use to download the files (See my screenshot). Thanks for coming back to me image
  • KalebTheMaker
    That is very odd, when I load that page in chrome (and in incognito, not logged in) it shows a button just above the spatial block on the upper right hand side that says "download" from there you can download many formats of the files.
    I have added the .fbx file to github for download. Link to github is above.
    Let me know if that helps,
    -Kaleb Clark
  • gtg938v
    gtg938v over 5 years ago in reply to KalebTheMaker
    Kaleb,
    For some reason when I try to open the fbx file from github in fusion it gives me a failure. It's as if the file is corrupted? Or maybe it's the wrong version?
    Thank you for the help, I really love your project, and thank you for making it publically available.
    Rich
  • aosatx04
    aosatx04 over 5 years ago in reply to gtg938v
    Richard,
    I had no problems with fbx file. I'm currently using the following version of Fusion360;
    2.09.9930
    Active Plan: Fusion 360, Subscription
    macOS 10.16.0
  • aosatx04
    Richard,
    2.09.9930
    macOS 10.16.0
