Project Videos
  • Project Videos
Project Videos
Documents LoFi Beats to Solder To -- Episode-660
  • Author Author: cstanton
  • Date Created: 9 Aug 2024 2:32 PM Date Created
  • Last Updated Last Updated: 15 Aug 2024 1:53 PM
  • Views 2840 views
  • Comments 5 comments
Pick up your soldering iron and chill out as you focus and get into your zen headspace, kick back and listen to these LoFi beats in the background as you join the element14 presents team working away on their printed circuit boards. Let the stress melt away to the sizzling sounds of flux and paste as the components wick and slide into place. Whether it's leaded solder, unleaded solder or solder paste, whip out your solder sucker and solder wick and get to work.
Watch the Video or Listen In
What's your Go-To Soldering Hardware?
Do you solder at your workbench, or do you find yourself soldering on the go with a USB soldering iron? Do you prefer to work with a solder sucker, or is solder wick more your style? Leaded solder, or unleaded?
When it comes to soldering your project it can depend on what the purpose is. Whether you are repairing electronics or putting together a prototype project, you may find yourself choosing the type of soldering iron that is best suited for what you are doing at the time. Still, with products like multicomp pro's bench soldering iron or Pinecil's portable offering, there is a lot of room for soldering equipment of varying types depending on what you need.
Kit Yourself Out
Multicomp Pro Soldering Station multicomp pro 1 Buy Now
USB Soldering Iron multicomp pro 1 Buy Now
Desoldering station multicomp pro 1 Buy Now
You can find more at the Farnell/Newark/element14 online store.
Up Your Soldering Skills
Here are a selection of episodes and past videos to help you to solder:
  •  DIY Hot Plate for SMD Soldering Using Raspberry Pi Pico -- Episode 655
  •  Make your Own Auto-Sensing Solder Fume Extractor -- Episode 523
  •  Soldering Up the rc2014 Homebrew Z80 Computer Kit -- Episode 454
  •  Hand Soldered LED Oscilloscope -- Episode 408
  •  Macroscope Soldering Tool -- Episode 379
  •  Soldering A Voice Changer Kit -- The Learning Circuit 47
  •  Learn to Solder -- The Learning Circuit 07
  •  Basic Soldering Tools -- The Learning Circuit 06
  •  Three Tips to Improve Your Soldering - Workbench Wednesdays 52
  •  Pros and Cons of Low-Temp Solder Paste - Workbench Wednesdays 46
  •  Desoldering Wick Tips and Tricks with Superwick - Workbench Wednesdays 37
  •  Soldering Maintenance Myths -- Workbench Wednesdays 07
  •  Capacitor Replacement on a Commodore 64 - A Lesson in Through-Hole Soldering -- Workbench Wednesdays 04
  •  Considerations for Solder Station Upgrades -- Workbench Wednesdays 03
  •  Ben Heck Teaches Alyson How to Solder Episode -- Episode 161
  •  Ben's Wearable Solder Gauntlet Part 2 Episode -- Episode 140
  •  Ben's Wearable Solder Gauntlet Part 1 Episode -- Episode 139
  •  Ben Heck's Surface Mount Soldering Tips and Tricks Episode -- Episode 119
  •  Ben's Home-Brew Solder Reflow Oven 2.0 Episode -- Episode 116
  •  Watch Ben's Soldering Tutorial Episode -- Episode 55
  • solder
  • soldering station
  • multicomp pro
  • solder paste
  • lofi beats
  • soldering iron
  • soldering
  • friday_release
  • opalko
    opalko over 1 year ago in reply to phoenixcomm +2
    Thanks for the soldering school page. I noticed that the links for NASA STD manuals are dead. I have listed updated links below: NASA NPC200-4: http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19720064032_1972064032…
  • opalko
    NASA NPC200-4:
    http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19720064032_1972064032.pdf
    Dead link but can be found at:
    https://ntrs.nasa.gov/api/citations/19930003486/downloads/19930003486.pdf
    NASA-STD-8739.3:
    http://www.phoenixcomm.net/~phnx2000/sim/library/NASA-STD-8739.3.1.pdf
    is a dead link but can be found at:
    https://nepp.nasa.gov/docuploads/06AA01BA-FC7E-4094-AE829CE371A7B05D/NASA-STD-8739.3.pdf
    NASA-STD-8739.4:
    http://www.phoenixcomm.net/~phnx2000/sim/library/NASA-STD-8739.4.pdf
    Is a dead link but can be found at:
    https://standards.nasa.gov/sites/default/files/standards/NASA/A/4/nasa-std-87394a_w_change_4_0.pdf
    IPC J-STD-001ES:
    https://nepp.nasa.gov/index.cfm/22093
    Dead link but could only be found at:
    https://web.archive.org/web/20120515213852/http://www.ipc.org/4.0_Knowledge/4.1_Standards/IPC-J-STD-001ES.pdf
    (IPC appears to have scrubbed their site of any free downloads that I could find)
    Cheers,
    Robert Opalko
  • e14phil
    e14phil over 1 year ago in reply to phoenixcomm
    Hey phoenixcomm,
    Great recommendation thank you so much! NASA certifications sound incredible, I would trust my life to your soldering skills.
    This video was just "Slow TV" from B-Roll of the element14 presents teams work, this is not meant to be educational in any way.
    We hope people who solder in mission critical situations are paying attention to certifications and folk like your self not this video.
    Folks please do check out the recommendations in the comments above.  <3
  • phoenixcomm
    phoenixcomm over 1 year ago
    This video should have never been posted I take grate exception to this technique as nothing show is considered good practice!!!!  I had NASA certifications. NEVER NO HOW JUST DON'T DO THIS EVER!!! This is horrid practice he went to the IC (first one) and hit with a soldering Iron with out a heat sink in place! FAILURE!! Stuff like this show nothing but bad techniques! and mp2100  never use the USB iron! it has ZERO RECOVERY TIME!! The way this should be done is with low temp solder paste and then a hot air station!
    If you are interested in soldering techniques  look a my blog posts called Soldering School. Read Learn. ~~~ Cris H.
    dougw over 2 years ago
    I use an old Hakko 936 for most work despite also owning several newer and fancier soldering stations. I guess there is a reason why there are so many clones of this design.
  • mp2100
    mp2100 over 2 years ago
    Mmmmm 2 hours of soldering video.  Love it. Still watching, hoping to learn a few techniques. The whole time watching, I am smelling the flux smoke.  Really.  I see the smoke rising and my brain smells it.
    and yes, I do travel with the mini USB powered soldering iron, I admit it.
