Project Videos
  • Project Videos
Project Videos
Documents Modding a Super 8 Camera into a Digital One -- Episode 382
  • Author Author: Matt
  • Date Created: 19 Dec 2018 4:20 AM Date Created
  • Last Updated Last Updated: 23 Jun 2025 12:39 PM
  • Views 13463 views
  • Likes 9 likes
  • Comments 30 comments
Watch the Episode
One mans trash is a makers treasure! Clem found a super8 camera in the trash, and soon realised that the original analogue films and the processing is crazy expensive nowadays. So he creates a drop in replacement for the film cartridge that turns the super8 camera into a digital one! But that is easier said than done!
Clem's Frequently Asked Questions
Why is the image quality so bad compared to modern cameras?
This super 8 camera is 47 years old. The films originally used were very light sensitive (much more than any modern sensor that could fit in there) and even with the correct film home videos filmed in super 8 looked like that. The lens is what determines picture quality for the most part. if you want to see the difference a lens makes check out videos on my personal channel (http://youtube.com/mayermakes) and watch some the oldest and newest videos those were shot with the exact same camera(Nikon D3300) but with different lenses(old: Kit lens f4.5, new Nikkor 35mm prime lens f1.8) and more light. you may understand it better if you see it for yourself.
So the look of the footage I've taken with the Super8 camera is pretty authentic for "1970s home video". that is just how it was when your Parents were young, or even grandparents depending on how old you are.
Couldn't you just remove the lens of the picam and put it directly in place of the film?
No.Tried that in multiple version, but no the focal distance and the sensor width are extremely different, you can only get a blotch of light by doing that+ you can't even get to the exact same plane because of parts that would hold the original film and should not be damaged.
How did you get it to focus then?
Extended the picam lens to near maximum and found a position that allowed me to get alignment with the shutter by trial and error, focused to UE and pushed back and forth until the image was mostly sharp. this ended up being a position multiple centimetres back which resulted in the need to extend the case.
Why the big case?
See above + I damaged multiple flat flex cables when fitting everything in the tiny version ,with only a day left until deadline i had to make sure that won't happen again + easier to install the buttons.
Will you do another version?
I plan to but It may be  a longer term project with dedicated self developed hardware.
if you would like to see that leave it in the comments below.
Supplemental Images and Links:
-  Episode 382 Resource Files
-  Super 8 Camera Digitizer -- Episode 505
{gallery} My Gallery Title
Bill of Material:
Part
Raspberry Pi 3A+
Raspberry Pi 1 Buy Now
Raspberry Pi Camera
Adafruit powerboost 1000 Adafruit 1 Buy Now
Tactile Switch, B3F Series, Top Actuated, Through Hole, Round Button, 100 gf, 50mA at 24VDC OMRON 1 Buy Now
Signal Relay, 3 VDC, DPDT, 1 A, TQ Series, Through Hole, Non Latching Panasonic 1 Buy Now
METAL FILM RESISTOR, 1KOHM, 500mW, 1% TT Electroniks Welwyn 1 Buy Now
LED, Red, Through Hole, 5mm, 20 mA, 1.8 V, 643 nm MULTICOMP 1 Buy Now
molex Board Connector FFC / FPC Board 1 mm, 15 Contacts, Receptacle, Easy-On 52610, Surface Mount molex 2 Buy Now
molex Premo Flex Jumper FFC / FPC Cable, 14 Core, 1 mm, Same Sided Contacts, 12 ", 305 mm, White molex 1 Buy Now
Additional Parts
Product Name
Stranded Wire
Used Super 8 camera
Kodak Super 8 Film cartridge for Size and Position Reference
3D printed Case and Buttons (files are available for download)
element14 Presents  |  MAYER MAKES VCP Profile  |  Project Videos
  • clem
  • super 8
  • e14presents_mayermakes
  • camera
  • upcycling
  • friday_release
  • mayermakes
  • e14p_CMM
  • mayermakes
    mayermakes over 7 years ago in reply to davedarko +2
    yes, but you need it to compensate the focal distance and sensor widht inside the camera. without the original lens you can´t see anything. it is extended to nearly it´s maximum.
  • mayermakes
    mayermakes over 7 years ago +2
    on popular demand here are some FAQs: Why is the imagequality so bad compared to modern cameras? this super 8 camera is 47years old. The filmes originally used were very light sensitive (much more than…
  • devinlhardy
    devinlhardy over 5 years ago +2
    Hi Clem, My name is Devin L. Hardy, I am a filmmaker/writer living in Los Angeles, CA. My resume consists of stints at 21st Century Fox, Academy of Motion Picture Arts and Sciences, and Netflix, just to…
  • daxtonanderson
    daxtonanderson over 7 years ago
    Noticed you fell back to external power for the project because the powerboost 1000 just barely couldn't keep up.
    I recommend running rpi-config and finding the clock speed line and lowering it from 1.4Ghz to around 900Mhz. A quadA53 at the 1.4Ghz is way overkill for transcoding a 1080p video source.
    If you're still running into power issues, disable bluetooth/wifi. If STILL running into issues, knock transcoding down to 720p (since the video is blurry anyways you likely won't notice a difference) and lower the clock down to 500-700mhz. You'll deffo be able to run on the Powerboost 1000 and battery life will be great!
    Switching the project to a PiZero is also a basic solution as it's much more power efficient
    DAB over 7 years ago in reply to mayermakes
    Hi Clem,
    If you can remove the 8-mm camera lens, you can set it up on an optical bench to get a better measurement as to where the focal point is.
    After that, you can bench test the RPi camera to find its focal point in relation to the other lens.
    The problem is the poor quality of the RPi lens. It really limits your performance. That and the low sensitivity of the sensor.
    Still, it is a good way to repurpose an old camera.
    FYI, if you try to go for an IR camera with this set up, be aware that the focal point will shift, so you will have to refocus the RPi camera using IR light only.
    beacon_dave over 7 years ago in reply to mayermakes
    The areas I was thinking of were mainly lower cost ways of:
    • Getting better 'followcam' camera solutions for web conferencing apps. Most are expecting a USB web cam however most USB web cameras aren't as flexible as even a low cost camcorder. Few camcorders declare if they support USB webcam functionality. HDMI or HD-SDI to USB convertors are still costly. It would be great to get a low cost USB webcam type solution that you can stick on a tripod and have ergonomic lens control over focus, iris, zoom to frame your shots.
    • Similar to above but for live streaming applications, so instead of a USB output a RTMP/RTSP/SRT stream or similar over IP to a Wowza streaming server or to YouTube / Facebook. Camcorders with live stream functionality are still relatively expensive, as are external encoders.
    • As above but for static camera applications. The ability to use a close-up lens for monitoring a science experiment or machine vision type scenario. I have used low end AXIS M10xx series CCTV cameras for this in the past on incubators but the lenses are fixed and not really suited to the job even though the electronics for streaming is adequate. Point Grey have some high end USB machine vision stuff but rather expensive for some education activities.
    • As above but for where you want to be able to deploy a large number of static cameras to live stream a larger event in conjunction with higher end equipment. Perhaps you need 25 to 50 simultaneous streams to give a general wide coverage overview of an event, with a 2 or 3 higher end roving streaming camcorders doing the interviews. A R-Pi with a camera module in a 3D printed housing with an appropriate lens arrangement would likely get the job done at a relatively low cost.
  • mayermakes
    mayermakes over 7 years ago in reply to beacon_dave
    I think there is a market for special snesor/lens combos for the pi and other sbcs, for example IR vision, extremely wide lenses for security cam projects or machinevision, macros for inspection and research projects, like cell tracking (our VCP Enrico did a project on this topic).
    Maybe if i can roll this into a purpose built hardware it comes with the option for such lenses.
  • mayermakes
    mayermakes over 7 years ago in reply to DAB
    You are desribing my procedure in the best way anyone could phrase it. it was a huge feat of trial and error to get close to the right combination of "inner lens" and Super8 lense.
    The projection idea also came to my mind but I could not pull it off, even shining a studio light directly into the lense did not generate an easy to focus image in the close range,  so I got back to triying out a few combinations until I got something that was recognizable as an image (seen in the video as the direct stream from the pi)
    I've always been surprised that there doesn't appear to be more off-the shelf options for getting better lenses onto a R-Pi camera solution.
    The closest I've found is the Arducam camera module which allows you to attach M12 or CS mount CCTV type lenses and attach it to the R-Pi via the CSI camera interface.
    Rev.C OV5647 Camera for Raspberry Pi Improves the Optical Performance | Arduino Based Camera
    Same applies to USB webcams - it would be great to be able to get a class compliant imager but one which allowed you to use interchangeable lenses giving a low cost way to get better quality video into your USB webcam applications.
    Very good episode Clem.
    I have considered doing something similar.
    I think you are right about not using the RPi camera without its lens. The normal footprint for the lens is 8-mm and your RPi camera is much smaller than that.
    What your doing now is called eyepiece projection. You will need to position the RPi camera very precisely so that the focal point of the RPi lens is at the focal point of the 8-mm camera lens.
    To do this well, you will need to set up the 8-mm camera with a well illuminated image about ten or so feet away. It is not a full far field, but it might be good enough if you have focus control on the 8-mm lens.
    Then you adjust the position of the RPi camera until the image is in focus. Then run through the zoom range of the 8-mm lens to see how well the image stays in focus.
    When you are happy with it, lock it down.
    It will never be a great camera, but it will be a one of a kind retro looking digital camera.
  • mayermakes
    this super 8 camera is 47years old. The filmes originally used were very light sensitive (much more than any modern sensor that could fit in there) and even with the correct film homevideos filmed in super 8 looked like that. the Lense is what determines picture quality for the most part. if you want to see the difference a lens makes check out videos on my personal channel (http://youtube.com/mayermakes) and watch some the oldest and newest videos those were shot with the exact same camera(Nikon D3300) but with different lenses(old: Kit lense f4.5, new Nikkor 35mm prime lense f1.8) and more light. you may understand it better if you see it for yourself.
    So the look of the footage Iǘe taken with the Super8 camera is pretty authentic for "1970s homevideo". that is jsut how it was when your Parents were young, or even grandparents depending on how old you are.
    No.Tried that in multiple version, but no the focal distance and the sensor width are extremely different, you can only get a blotch of light by doing that+ you can't even get to the exact same plane because of parts that would hold the original film and schould not be damaged.
    Extended the picam lense to near maximum and found a position that allowed me to get allignment with the shutter by trial and error, focused to UE and pushed back and forth until the image was mostly sharp. this ended up beeing a position multiple centimeters back which resulted in the need to extend the case.
    Why the big case?
    will you do another version?
  • mayermakes
  • davedarko
    davedarko over 7 years ago
    Did you try to remove the lens on the pi cam module?
