WorkBench Wednesdays
  • WorkBench Wednesdays
WBW Episodes How to Profile Battery Usage for IoT Devices - Workbench Wednesdays 56
  • Episodes
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 31 May 2022 5:08 PM Date Created
  • Last Updated Last Updated: 15 Jun 2022 7:24 AM
  • Views 55069 views
  • Comments 8 comments
When running on a battery, it is important to know what parts of your circuit draw the most current. Profiling is a process where you look at sections of code or interactions with hardware to see how much power each requires. In this video, James shows four tools (and their tradeoffs) when profiling IoT or Edge Machine Learning devices. See if it makes more sense for you to use a Digital Multimeter (DMM), Power Supply with history graphs, an oscilloscope
Supplemental Content:
  • WorkBench Wednesdays #54 Oscilloscope Acquisitions modes
  • WorkBench Wednesdays #40: Measurements with an SMU
  • WorkBench Wednesdays #53: B&K 9140 Overview
  • Nordic Power Profile Kit II (PPK2) by ralphjy
Bill of Material:
Bench Power Supply BK9140, Programmable, 3 Output, 0 V, 32 V, 0 A, 8 A BK Precision 1 Buy Now
NGU401COM - Source Measurement Unit (4-quadrant) Rohde & Schwarz 1 Buy Now
MP730028 US Bench DMM, 5.5 Digits Multicomp Pro 1 Buy Now
MP7300256 Handheld DMM 3.75 Digits with Bluetooth Multicomp Pro 1 Buy Now
RTM3000 - 4 Channel Oscilloscope (RTM3K-COM4) Rohde & Schwarz 1 Buy Now
Oscilloscope Current Clamp Probe RT-ZC20B Rohde & Schwarz 1 Buy Now
Power Profilier Kit II (NRF-PPK2) Nordic Semiconductor 1 Buy Now
element14 presents
element14 Presents  |  About James|  Workbench Wednesdays
  • IoT Battery Life
  • Battery Consumption
  • Energy consumption
  • Battery profiling
  • battery life
  • james
  • workbench wednesdays
  • baldengineer
    baldengineer over 3 years ago in reply to Hari-Seldon
    Can you share pictures of your connections?
  • Hari-Seldon
    Hari-Seldon over 3 years ago in reply to baldengineer
    I sure did…
    I also tried following the instructions and doing Source mode… same noise.  This is what had me thinking I may just have a faulty device.
  • baldengineer
    Did you put the PPK into Ampere meter mode?
    Under mode, that is a toggle for "Source Meter" and "Ampere meter." It defaults to source meter (where the PPK provides power.)
    Also, you might try turning the device on and off while connected. It'll cause the nRF Connect software to reflash it (if necessary).
  • Hari-Seldon
    Hari-Seldon over 3 years ago in reply to Hari-Seldon
    oh, and of course I tried different wires!
  • Hari-Seldon
    I didn't completely clarify, on the LED test if I wired VOUT and GND, then the LED came on... but still not anything but noise on the software for the PPK2.
  • Hari-Seldon
    I've bought the PPK2 and either I'm a moron, or the device is faulty.  How do you suggest I figure out which it is (right now odds are even, in my view)?
    I tried it out with my DWM3001CDK, which has current measurement pins.  I've verified continuity there and that removing the jumper disables the MCU.  I've linked up my PPK2 wiring up VIN/VOUT on the current pins, and the two grounds onto the board GND.  Nothing but noise in the nano-amperes... it's worth noting the values don't change even if I disconnect the power from the DWM3001CDK... a pretty strong indicator that it's not actually doing anything.  I've also tried it with the PINs reversed, just in case I've done something terribly silly (which I'm sure I hadn't).
    Given that it didn't work, I tried a much more complex circuit.
    1. Bench power supply tied to + and - rails of a breadboard.
    2. Resistor and LED in series.
    Everything lights up fine...then I put the PPK in series and the LED won't come on, and it's just noise on the nRF connect Power Profiler.
    Anyone want to suggest a further test I might do?  Or even walk me through how you'd wire it up if yours works fine?
  • baldengineer
    baldengineer over 4 years ago in reply to koudelad
    I have a Joulescope. I backed the original Kickstarter. But I haven't used it enough!
  • koudelad
    koudelad over 4 years ago
    Nice little device from Nordic.
    ST also has a kit for power consumption measurement, especially (but no limited to) Nucleo boards. https://www.st.com/en/evaluation-tools/x-nucleo-lpm01a.html
    Another solution is a Joulescope. It doesn't have an integrated power supply, but performs great for the price. We also use it at work for longer data logging. https://www.joulescope.com/
    I used Joulescope for a power profiling of my IR thermometer: /challenges-projects/project14/energy-harvesting/b/blog/posts/measuring-nanoamps and I was suprised how well it performed against a Keysight precision DC supply that was about $14 000: /challenges-projects/project14/energy-harvesting/b/blog/posts/measuring-nanoamps#jive_content_id_Keysight_N6705CN6705C_power_supply_with_N6781AN6781A_unit
