555 Timer Madness
  • 555 Timer Madness
555 Timer Madness
Blog Project14 | 555 Timer Madness: Do Something Special or Unusual using 555 Timers
Join 555 Timer Madness to participate - click to join for free!
  • Date Created: 15 Aug 2022 8:01 PM Date Created
  • Views 29071 views
  • Likes 15 likes
  • Comments 14 comments
  • 555timermadnessch
tariq.ahmad
tariq.ahmad
15 Aug 2022
In the Comments Below:
Give Us Your Weird or Unusual 555 Timer Ideas!
If we like your idea you could win free swag or parts to use in your project!
"That 555 family was a total surprise.  I wanted to make it flexible, that was the whole purpose, but I didn’t realize it was so flexible.  There are applications now that still sound crazy to me.  And the quantity!  In the second year it moved to the largest quantity sold of any IC and it has stayed that way for 30 years.  The original application was as a timer and oscillator, but it has moved well beyond that." - Hans R. Camenzind, inventor of the 555 Timer
imageIn honor of the 50th anniversary of the release of the first 555 Timer,  we are launching a 555 Timer Madness competition.  The 555 Timer Madness contest challenges you to do something special or unusual using 555 timers.   The 555 timer is very versatile and it can be used in a variety of circuits and in unusual circuits such as a Schmidt triggers, abstable gadgets, long period timers, LED flashers and alarms, signal injectors, egg timers, continuity timers, morse code timers, beeping prank devices, security trip alarms, music synthesizers, traffic light control systems, and more.  You are free to submit any project as long as it has a 555 timer in it.   Since this a 555 Timer Madness competition we are most interested in projects that feature something weird  or unusual using 555 timers!
Submit Your 555 Timer Projects Here:
Submit Entry
Submit your blog in  555 Timer Madness  or tag your project blog 555timermadnessch
Deadline:   Submit your project anytime from now until the 18th of October!
A 555 timer IC or 555 oscillator is a cheap and helpful precision timing device that can act as a simple timer to generate single pulses or long-time delays, or as a relaxation oscillator producing a string of stabilized string waveforms of varying duty cycles, ranging from 50 to 100%. The timer is so named because it packs a trio of internally connected 5 kΩ resistors to generate two comparative reference voltages. It’s also an incredibly robust 8-pin chip that can act as a monostable, bistable, or astable (the output voltage rises and falls in a stable pattern) multivibrator, making it suitable for a myriad of applications, including delay timers, pulse generators, LED and lamp flashers, alarms, tone generators, logic clocks, frequency division, power supplies, and more. The 555 timer hasn’t changed much since its inception in 1971. The first prototypes were released as the NE555V (plastic DIP) and SE555T (metal TO-5), which were differentiated by a dual in-line package and a metal-semiconductor package, respectively. Signetics would announce the NE555 timer/oscillator IC in 1972, and in that same year, the timer was produced by 12 different companies and quickly became a best-selling product for electronics manufacturers. There are two different types of 555 timers, both being eight-pin chips. The most common offers a rectangular ‘V’ package, denoted by four pins placed down each side. The other version, which was previously the most common but has now fallen from favor somewhat, is the circular ‘T’ package that looks similar to a capacitor.image
You can learn more about the 555 Timer by downloading the following ebook:  The Fundamentals of 555 Timers - eBook
The 555 Timer was designed by Hans Camenzind in 1955 and is based on an idea for the 555 timer/oscillator chip that grew out of his earlier electronics experiences.  Growing up in Zurich, Switzerland, he learned to fix radios before going to college. In 1960, Hans and his wife moved to the US whe he earned an MSEE from Northeastern University in Boston.   He joined Signetics in 1968 because he wanted to design linear circuits and thought the company would give Fairchild Semiconductor a serious run in the linear IC market. By 1970, he resigned and became an independent contractor and IC designer, after feeling like Signetics, who became his first customer, had lost their way.It was as a consultant for Signetics, that Hans designed the 555 timer’s circuit and created its physical layout.  Although you could say that the name 555 timer comes from the three 5k resistors in its internal circuit, according to Hans R Camenzind that's not exactly the case.   According to him, it was Signetics manager, ArtFury’s love for the number “555” that led to the naming of the circuit.  As it would turn out the 555 timer chip, easily outlasted Signetics who released the first 555 timer, by several decades. Philips Semiconductors (which was spun off and renamed NXP in 2006) would acquire Signetics in 1975, eventually retire their brand.   You can read an oral history of Hans Camenzind here:  THE 555 TIMER IC AN INTERVIEW WITH HANS CAMENZIND - THE DESIGNER OF THE MOST SUCCESSFUL INTEGRATED CIRCUIT EVER DEVELOPED
Here are some 555 Timer Projects to help inspire you:
Episode 552 - Magical Potion Bottle Rack
The Learning Circuit 67: 555 Timer Project | Flashing LED Headband
555cc by jc2048
555 Timer Voltage Inverter by fmilburn
The Learning Circuit: 63: LED Dominos Using a 555 Timer
555 Frequency Synthesizer by jc2048
Your Chance to Win
Be Original
Stick to the Theme
  • You could come up with a clever name that make's your project memorable!
    • This project is your baby! Part of the fun of bringing something new into the world is coming up with a name.
  • Your project could introduce something new or that is not commercially available or affordable!
  • If you have an idea for a project that doesn't fit the current theme then submit your idea in the comments section of the monthly poll.
List the Steps
Submit Video Proof
  • Provide the steps you took to complete your project (text, video, or images).
    • This could be a step by step how-to-guide, vlog, schematics, coding, napkin drawings, voice narration, or whatever you think will be useful!
  • If it doesn't work that's fine, this is more about the journey than the end product.
  • A short video is all that is required but you can shoot as much video as you like.
  • You are encouraged to be creative and have as much fun as possible!
Your Prizes
One Grand Prize Winner Wins a $200 Shopping Bundle Three First Place Winners Win  a $100 Shopping Cart
  • One Grand Prize Winner Wins a $200 Shopping Cart!
  • 3 First Place Winners a Win $100 Shopping Cart!
image image
Some Terms & Conditions Apply:  How to Redeem Your Shopping Cart for Project14
Your Project, Your Ideas!
About Project14
Directions
Every month you'll have a new poll where you'll get to decide an upcoming project competition, based on your interests, that will take place a couple of months in advance. Themes are broad in scope so that everyone can participate regardless of skill set.
What are Monthly Themes?
  • Every month (around the 14th of each month) a new theme will be posted on Project14.
  • Submit your ideas (proposals) for your projects to get feedback from the rest of the community.
  • Submit a project entry in the Theme space once you start working on it.
What are Monthly Theme Polls?
  • Every month (around the 14th of each month) there is a project theme poll.
  • Vote on which project competition you want to see for the following upcoming theme.
    • The themes voted on during the previous poll decided the upcoming theme.
    • If you submit an idea for a theme that is not used then it can still be used in a future poll.
  • Themes comments and ideas from the comments section of the project theme poll.
Visit:  555 Timer Madness  or tag your project blog 555timermadnessch
You have until October 18th End of Day to submit your completed project!
A jury consisting of your peers will judge project submissions!
  • kmikemoo
    kmikemoo over 4 years ago +2
    Argh! I gotta think of something! The 555 is my favorite chip of all time. Sorry Arduino. I love you but I love the 555 more.
  • kmikemoo
    kmikemoo over 4 years ago in reply to AE7HD +1
    AE7HD I try to log in daily and I miss stuff all the time. Sorry. The Community is HUGE and there's so much cool stuff that it's hard to stay up on it all. If you want to participate in the contests…
  • kmikemoo
    If you want to participate in the contests, the Challenges & Projects tab and the Products > Roadtests tabs are your friend.  I try to check them every Friday when a new element14 Presents episode comes out.
  • flyingbean
    flyingbean over 4 years ago in reply to AE7HD
    Stay tuned with the community home page every day. 5 mins/day would reduce such mistakes. I think Element14.com has more contests/games this year than previous years.
  • AE7HD
    AE7HD over 4 years ago
    Augh! Why do I keep finding about these contests just before they are over? I've built so many things using 555 timers. I started using them shortly after Radio Shack started carrying them in the '70s.
  • robogary
    robogary over 4 years ago
    Tis the season for building a Halloween animatronic using 555s instead of using controllers.
  • rsjawale24
    rsjawale24 over 4 years ago
    I'm working on 555 timer-based temperature transmitter. The idea is to use the 555 in astable mode and replace one of the fixed resistors with a thermistor from the thermistors kit that I received as a part of the experimenting with thermistors challenge. The output frequency of the 555 will vary in accordance with the change in the thermistor resistance. I already tested it and it works. Now I'm stuck with the transmission of this frequency output. I'm looking at different ways that can transmit this output freq. of the 555 wirelessly. Planning to use a 433MHz RF module for the same. Not sure if it will work.
