Project14
Project14
Blog Project14 | Winners Announcement: Off the Grid Projects!
  • Theme Suggestions
  • Date Created: 30 Jun 2023 2:24 PM Date Created
  • Views 3606 views
  • Likes 16 likes
  • Comments 19 comments
  • winners announcement
  • off the grid
  • project14
  • offthegridch
tariq.ahmad
tariq.ahmad
30 Jun 2023
The Off the Grid project competition challenged you to work on projects that help you easily get off the grid such as Gate opener control system, 8-10k Solar Array, Water Tank Monitoring, and Solar Monitoring Stations.  We had two really great projects by  robogary who built a tropical beverage cooling mug and  misaz  with his mini solar powered temperature sensor, as well as, some great starts from rsc talking about his start on a ham radio and solar power charging station and  scottiebabe  with their dead battery lamp.  For this contest,   we're going to split the prize pool between robogary and misaz .
Congratulations to robogary  and misaz  you are the Grand Prize Winners and you win a $250 shopping cart!
Without further adieu here are your winners:
The Winners:
 Solar Powered Tropical Beverage Cooling Mug -Blog #1 - the concept by robogary
  •  Solar Powered Tropical Beverage Cooling Mug - blog #2 - the solar panel characterization
  •  Solar Powered Tropical Beverage Cooling Mug -Blog #3 - the solar charging system
  •  Solar Powered Tropical Beverage Cooling Mug -Blog #4 – Learning to cool with Peltier modules
  •  Solar Powered Tropical Beverage Cooling Mug -Blog #5 –*DRAMATIC* step fwd- building a Peltier module chill plate/fan cooled heatsink assembly.
  •  Solar Powered Tropical Beverage Cooling Mug -Final Blog (#6)- Hilarious summary details of an Off the Grid folly
The vision for this Off the Grid project is all about a tropical island beach. No phone, no lights, no motorcar , only a couple luxuries: a beach chair, a fishing rod, a solar reflector grill or a wood beach fire for my seafood buffet, and a trusty solar powered mug that keeps your favorite beach beverage cool. Engineering style blogs follow, documenting the experiments and learning what it takes to build utopia.
{gallery}My Gallery Title
 Mini Solar Powered Wireless Temperature Sensor by misaz
This is very compact solar powered temperature sensor with resolution of 0.005°C and accuracy of 0.25°C. Measured temperature and few other service information are remotely transmitted using 868 MHz band to the gateway. The device has absolutely no battery. Instead of battery it relies only on the mini 35 x 14 mm (1.38 x 0.55 inch) solar cell and one supercapacitor which allows running it in field for several years without need of any maintenance.
Keep Being Awesome and Thank You for your continued support of Project14!
Be sure to congratulate the Winners in the Comments Below!
  • robogary
    robogary over 2 years ago
    Congrats misaz  , it is an honor to share the winner platform with you.  All the projects are insighful.
    This contest is a coincidental prelude of things to come. This week at work, I started working on an OFF THE GRID demo system using solar panels to power the 300V DC link of a 230 VAC VFD drive that automatically powers a water pump. My demo is only 1HP tho.
    Using a similar approach as in my Tropical Beverage project, I started by testing a pair of 100W 18V solar panels using resistive loads, checking power curves and performance in different outdoor conditions. Wired these solar panels in series and retested. I'm having alot of fun specifying all the plumbing too, pump, check valves, ball valves, pressure and flow transducers, tanks, etc.. :-)  The final version uses 17 solar panels in series to get that 300+ Vdc.
    I understand these OFF THE GRID pump systems are common around the vineyards in Spain and South America.
  • misaz
    misaz over 2 years ago in reply to robogary
    Congrats robogary . I also like sharing winner platform with you. I was thinking about it and it must be super hard to compare our projects and select which one is better since they are completly different even they have shared property - uses solar pannel. Splitting reward pool is the best solution of this situation I think. I think that scottiebabe should post their forum post as blog instead. It was also very nice project.
  • robogary
    robogary over 2 years ago in reply to misaz
    Judging is super hard, the projects submitted by E14 members are clever and well done. I can avoid judging by entering each competition. scottiebabe gave us a break on this one so she could sun on the beach with her USB power meter  :-)
  • robogary
  • scottiebabe
    scottiebabe over 2 years ago in reply to robogary
    This comment was deleted.
    beacon_dave over 2 years ago in reply to scottiebabe
    I could do with a bit of that sunshine here.
    My USB power meter is currently telling me that "there is no way that solar panel is going to re-charge that power bank anytime soon..."
    'Dead' battery juicing however is looking a lot more promising. Five juiced batteries later and the charge status indicator is showing that the powerbank is actually charging and not just putting on a light show.
  • scottiebabe
    scottiebabe over 2 years ago in reply to beacon_dave
    You mean the one that is powered by the battery pack you are trying to recharge ? Slight smile
