IoT: In the Cloud
  • IoT: In the Cloud
IoT: In the Cloud
Blog Arduino MKR WIFI 1010 and Amazon Web Services: Safe MQTT with SSL and Certificate
Join IoT: In the Cloud to participate - click to join for free!
  • Date Created: 15 Mar 2019 5:04 PM Date Created
  • Views 5353 views
  • Likes 13 likes
  • Comments 13 comments
  • mqtt
  • mkr_1010
  • arduino mkr 1010
  • p14 mkr 1010
  • arduino_iot_cloud
  • aws
  • ssl
  • iotcloudch
  • certificate
  • secure
  • iot
15 Mar 2019
IoT: In the Cloud
Enter Your Project for a chance to win an Arduino MKR WAN 1300 Kit with a Compatable Lora Gateway or an MKR 1400 GSM with a Shield Combo + a $100 shopping cart!
Project14 Home
Monthly Themes
Monthly Theme Poll
I'm preparing a project for Arduino Day.
I'll need to connect an Arduino MKR 1010 (thank you element14!) with AWS IoT.
And good news: the Arduino example is safe. An example where the safety is embedded from the get go.
Respect.
The exercise is easy. I just had to follow the tutorial from arduino.cc to make it work. And that proves that it isn't impossible to get everyone started with safe solution. The supplier just has to put the effort in to write the instructions and have no example where security is omitted.
What do you need?
You'll have to get a free AWS account, a Arduino MKR 1010 and a WiFi connection to the internet.
I am not repeating the excellent tutorial. If you haven't done so, read it now. Just follow it step by step.
There's one correction: where the tutorial says to download ArduinoMqtt, you actually have to install ArduinoMqttClient.
The example did compile out of the box on Arduino IDE 1.8.8. I had a compile error with version 1.8.1.
What does it do?
The sketch first logs on to your WiFi router. It will then make an SSL connection to AWS.
WiFiClient    wifiClient;            // Used for the TCP socket connection
BearSSLClient sslClient(wifiClient); // Used for SSL/TLS connection, integrates with ECC508
MqttClient    mqttClient(sslClient);
It uses certificates for authentication.
Once that's successful, it'll send messages to the topic arduino/outgoing and subscribe to messages posted on arduino/incoming.
Here you see messages from the MKR1010 arriving in AWS:
And this is a message from AWS retrieved by the MKR1010.
related blog posts
Manage Arduino MKR WIFI 1010 Battery Life in the Cloud - How Long until the Next Recharge?
Project14 | IoT in the Cloud: Make Use of a Wireless Technology and a Cloud Provider!
Keithley DMM6500: Measure Amp-Hours of an Arduino MKR WIFI 1010
Manage Arduino MKR WIFI 1010 Battery Life in the Cloud - AWS, Graphs and Alerts
Arduino MKR 10xx, ETH Shield and Amazon Web Services: Safe MQTT with SSL and Certificate
    dubbie over 7 years ago +2
    Jan, I want to get a better understanding of IoT so I will follow your advice and work through the tutorial. Do you know if it will work with a MKR 1000 (rather than MKR 1010) as that is what I have. …
    Jan Cumps over 7 years ago in reply to dubbie +2
    no idea, Dubbie. I have this one since a few days and followed the tutorials. I don't have a 1000.
  • fmilburn
    fmilburn over 7 years ago in reply to fmilburn +2
    I went back this morning and started over and now it is working and I have no clue what is different. I have set up WiFi numerous times on Arduino, TI, and ESP microcontrollers without a problem. I usually…
  • kiri-ll
    kiri-ll over 7 years ago
    What attracted my attention is MQTT. I've seen so many times, how people solve *everything* with HTTP. Like there is nothing more in the network.
    I am very glad to see the screw being handled with a screwdriver, not a hammer image
    Jan Cumps over 7 years ago in reply to kiri-ll
    If that HTTP is a call to a web service, I'd say it's OK.
  • kiri-ll
    kiri-ll over 7 years ago in reply to Jan Cumps
    I'd say network services should provide HTTP for people, and machine-reasonable protocols for IoT
  • kiri-ll
