Op-Amp-a-Palooza
  • Op-Amp-a-Palooza
Op-Amp-a-Palooza
Blog Op-Amp Line Follower - Blog 3 The Line Follower
Join Op-Amp-a-Palooza to participate - click to join for free!
  • Author Author: javagoza
  • Date Created: 27 Apr 2022 5:34 PM Date Created
  • Views 34606 views
  • Likes 11 likes
  • Comments 11 comments
  • opampsch
  • line follower
  • pwm
  • opamps
  • Op-amp-a-Palooza
javagoza
javagoza
27 Apr 2022
In the two previous blogs we have been describing the problems we have encountered to finish this project and the decisions made. We were initially going to build a line following vehicle built with op amps with a PID controller. Due to errors in the tests we had to limit the scope of the project and in the end the vehicle is finished but only with proportional control. In this blog we describe the final construction and show proofs of its operation. For the construction of the vehicle we have used parts of the TI-RSLK kit manufactured by Element14, the chassis, the DC motors and the motor driver and power distribution board.
The Op-Amp Line Follower
This line following vehicle uses two light dependent resistors, LDR, to capture the light emitted by two yellow LEDs that is reflected by the surface of the track on which the vehicle is traveling. In this way it can detect the black line that reflects less light and by means of a proportional control correct the direction of the vehicle by modifying the speed of the motors.
The proportional control of the motors is carried out according to the intensity level of the light received by the photocell sensor. A pulse width modulation PWM signal is used to finely control the motor speed.
The vehicle control can be fine-tuned by means of two potentiometers that adjust the voltage level that will be obtained when the photoresistors are on the lightest surface, the darkest or in between.
The brightest light intensity level received by the sensor, when the sensor is out of line to follow, will result in a higher PWM duty cycle percentage and the darkest light intensity level received by the photoresistor, when the sensor is over line to follow, will result in a lower PWM duty cycle percentage.
The vehicle uses only analog electronics. The PWM controller works by comparing a triangle wave with the voltage received from the two sensors. The two sensors are adjusted by a voltage divider. When comparing the received voltage with the ramps of the triangular wave, two comparators generate the amplitude modulated pulses.
The triangle wave generator circuit has three blocks. A block that generates a reference voltage that will be half the supply voltage of the circuit. A comparator circuit with hysteresis or Schmitt Trigger that will generate a square wave and an integrating circuit. By integrating the two constants that the square wave gives us, it will generate two ramps, one increasing and then another decreasing, our triangular wave.
Schematics
R4 = 40 kohm, R6 = 40 kohm. In the PCB R4 = 47 kohm and R6 = 180 kohm, experimental values
Bill of Materials:
Product Name Manufacturer Quantity
Trimpot, Multi Turn, Cermet, Top Adjust, 50 kohm, Through Hole, 12 Turns BOURNS 2 Buy Now
Through Hole Resistor, 470 kΩ,
MULTICOMP PRO​ 2 Buy Now
Through Hole Resistor, 10kΩ
MULTICOMP PRO​ 1 Buy Now
 Through Hole Resistor, 100 Ω MULTICOMP PRO 2 Buy Now
 Through Hole Resistor, 120 kΩ MULTICOMP PRO 1 Buy Now
 Through Hole Resistor, 180 kΩ MULTICOMP PRO 1  Buy Now
Through Hole Resistor, 47 kΩ MULTICOMP PRO 1 Buy Now
Capacitor, Metallized PET, 0.1 µF VISHAY 2 Buy Now
LDR, 1 Mohm, 250 mW, 320 V ADVANCED PHOTONIX 2 Buy Now
LM358P Operational Amplifier, 2 Amplifier TEXAS INSTRUMENTS Buy Now
MCP6007 2 OpAmps , 1 MHz, 1.9 V/µs, 1.8V to 5.5V, MSOP, 8 Pin MICROCHIP 2 Buy Now
OP484 Operational Amplifier, Quad, 4 Amplifier, 4.25 MHz ANALOG DEVICES 1 Buy Now
Wire-To-Board Terminal Block, 3.81 mm, 2 Ways, 26 AWG, 16 AWG, Screw
MULTICOMP PRO 4 Buy Now
Prototyping Board, Eurocard, FR2, Epoxy Paper, 1.5mm, 100mm x 160mm
ROTH ELEKTRONIK 1 Buy Now
LED, Yellow, Through Hole, T-1 3/4 (5mm), 20 mA, 2.1 V, 592 nm
8 Contacts, DIP Socket, 2.54 mm,
ARIES 1 Buy Now
14 Contacts, DIP Socket, 2.54 mm
ARIES 1 Buy Now
The OP484 is borrowed from this kit: Digilent - Analogue Part Kit
Alternative Parts:
Initially we started working with two MCP6007. See Op-Amp Line Follower - Blog 1 First Steps
IC Adapter, Fibreglass, 8-MSOP, 2.54mm Pitch Spacing, 7.62mm Row Pitch ROTH ELEKTRONIK 2 Buy Now
Chassis and motors:
Basic Robotic Kit, TI-RSLK Maze Edition, Mobile Platform ELEMENT14 1 Buy Now
Standoff spacers
Protoboard
With the help of Fritzing, we tested the layout of the components on the strip prototyping board.
For the prototype we use an Eurocard Prototyping Board , FR2, Epoxy Paper, 1.5mm, 100mm x 160mm, cut so that it does not protrude from the chassis and drilled in 4 places so that it can be fixed to the chassis with standoff spacers.
To cut the tracks that were not supposed to be connected we used a Duratool Track Cutter
This was the end result once the components were soldered to the prototyping board.
The fine adjustment potentiometers are located at the rear, in the most stable area of the robot so that the robot does not swing and change the distance of the sensors to the ground while adjustments are made.
A potentiometer has been placed to the right and another to the left corresponding to the motor on each side and in a position such that turning clockwise decreases the speed of the motor and turning counterclockwise of the clock increases the speed of the corresponding motor.
Top view of the control board.
And the back of the board.
The controller board is connected with Dupont cables to the line sensor and to the the Pololu motor driver and power distribution board.
Line sensor board
The line sensor with the two photoresistors and the two yellow LEDs are built on another board.
The line sensor is placed in the lower part of the chassis separated with standoff spacers at a small distance from the surface on which the vehicle is going to navigate. If the surface is not completely smooth, you have to leave more space with the ground.
Adjusting sensors sensitivity
Using the two trim-pots you can calibrate the sensitivity of the two sensors. The trim pots form a voltage divider with the photoresistors. You can adjust the input voltage to be between the peaks of the triangle wave. The Trim Pot Adjustment Tool for Bourns Trimmers is very useful for this task. Trim Pot Adjustement Tool
Quality Assurance
The quality assurance team testing the vehicle.
Testing his small circuit:
Trying to fool the line follower
This time the four colored squares along the line act as small traps, swerving the vehicle sharply. Finally the robot corrects the trajectory.
https://youtu.be/corH7r6yXTU
Next Steps: Playing with Line Follower - Puzzle pieces
Playing with the line follower is really fun. To increase its game possibilities, we have decided to create a series of puzzle pieces that allow us to make configurable paths.
The different kinds of puzzle pieces.
A couple of possible path configurations.
Thanks and conclusion
Thanks to the Project14 team for this opportunity to learn more about op amps and to the community members who have read the blogs and given us feedback and guided us through troubleshooting.
Project Blogs
  • Op-Amp Line Follower - Blog 1 First Steps
  • Op-Amp Line Follower - Blog 2 Following the research
  • Op-Amp Line Follower - Blog 3 The Line Follower
    DAB over 4 years ago
    OK, I am a little confused.
    What does OP2 do?
  • javagoza
    javagoza over 4 years ago in reply to DAB
    Hi DAB, I am not an electronics expert. I read in a TI document that the unused op amp should be connected in a way that is safe for the unused amp and doesn't affect the used amps. I may have misunderstood or perhaps I should have asked what was best to do. From my neophyte point of view I was not able to see the difference between having that amplifier connected or not, when in doubt I tried to follow TI's guide.
    The selection criteria for the op amps has been, what do I have at home that I can use?
    https://www.ti.com/lit/an/sloa277a/sloa277a.pdf
  • javagoza
