Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3968 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
    shabaz over 1 year ago
    Nice work! Interesting shape for a loop antenna. I notice you're using a decent analyzer..
    I've been trying to build a cheap analyzer, front panel below. (Not my design, it's some old magazine article). I'll write a blog post on it once I've worked on it a bit more.
    It won't be anywhere near as sophisticated as the one you're using, but hopefully usable at a pinch.
  • kmikemoo
    kmikemoo over 1 year ago in reply to shabaz
    shabaz VERY nice!  I look forward to your blog. Relaxed  I do also own the MFJ-259D, a NanoVNA and a TinySA.  BUT...not that I need another analyzer, but I'd love to build one - just because.
    I recently revisited your PicoSynthRF project.  Thank you for doing/sharing that. RelaxedThumbsup
  • kmikemoo
