Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 4115 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • kmikemoo
    kmikemoo over 1 year ago
    Here is a picture of the antenna in use today.
    For those that enjoy a challenge, here is a picture with a bit less zoom.  Can you find it?
    Even once you see it, it's hard to see it. Relaxed
    Not sure about the fox but I think we do have a tree climbing monkey in the vicinity
  • kmikemoo
    beacon_dave Great job!  On the first hunt I hosted, I did climb a tree.  My wife was not thrilled.  She made me bring a ladder on the next one.  I did that for a couple more, but those collapsible ladders aren't exactly light.  That's when I broke down and bought a telescoping painters pole.  After about 2 years of supervising me hiding the fox - and promising not to climb any more trees, she has finally allowed me to go out on my own.
  • kmikemoo
    Just that segment by itself looks like it should be part of a Benny Hill skit. Joy
