Spring Clean!
  • Spring Clean!
Spring Clean!
Spring Clean Projects 2025 2 Year Antenna Project
  • News and Projects
Join Spring Clean! to participate - click to join for free!
  • Author Author: kmikemoo
  • Date Created: 3 May 2025 4:16 AM Date Created
  • Views 4202 views
  • Likes 17 likes
  • Comments 28 comments
  • spring cleaning
  • antenna
kmikemoo
kmikemoo
3 May 2025
In the midst of this "work of art", is an antenna.  It's been there since March of 2023.
image     image
In January of 2023, I read an article in QEX (a magazine published by the ARRL) by Richard Quick, W4RQ, on a 2 meter loop antenna made with an aluminum yardstick.  I was intrigued.  I'm also forgetful sometimes - so I didn't get around to buying a yardstick until the weekend before I wanted to use the antenna (late March).  Being me, I also way over thought the project.  36 inches will surely be too short - so I bought a meter stick from Ace Hardware.  But the build instructions said use a yardstick - so I went back out and bought a yardstick from Harbor Freight.  At least that way I wouldn't be out a lot of money when the antenna ended up being too short.
Over the remainder of the weekend, I build both antennas.  Bend them in thirds.  The Harbor Freight one has a hole for hanging so that means the top bends are going to be extra short.  No problem.  I have infinite faith that the meter stick antenna will work flawlessly.  I have so much faith that I paint it right away.  The antenna is for a hidden transmitter so dulling that bright aluminum seems like the right thing to do.  One coat.  Let it dry.  Two coats.  Let it dry.  Now it's Thursday night.  I need this thing for Saturday morning at 0730.  I put it on the antenna analyzer and... its resonant frequency is 136MHz.  Fantastic for US NOAA Weather Satellites but a far cry from the 147.555MHz that my transmitter is going to use.  Try this.  Try that.  If I re-bend it, I'll mar the paint.  Admit defeat and go to bed.  Throw the antenna on the garage work bench.
After work the next day, it's 4th down and long yardage.  It's time for a Hail Mary play.  I get out the Harbor Freight yardstick version and put it on the antenna analyzer.  Tweak this.  Tweak that.  It's got its lowest Standing Wave Ratio (SWR) of 1.2 at 147.56MHz.  "Are you freakin' kidding me?!" and other rants ensue.  It's bright silver.  There's no time to paint.  Besides, it's cold in the garage and I'm not going to stink the house up with spray paint.  It will have to do.  "Seriously!!"
image     image
The bright silver Harbor Freight yardstick antenna worked great.  I had to enlist the wife's help to locate it after the event - even though I was standing right in front of the tree I hid it in.  All is well.
Except for that non-resonant antenna sitting on the workbench.
WELL... I finally made the time this week to tune it.  Two years later.  Cut.  Flatten.  Bend.  Drill.  Still too long.  Repeat.  I ended up taking off about... three inches total.  Imagine that.
image     image
Not bad.  When you are only transmitting 50mW, every little bit helps.
Now to work on all the other stuff on the bench. Frowning2
    beacon_dave over 1 year ago +1
    Looks like the original article is available here: https://dcarc.club/presentations/2023-01-02%20W4RQ%20QEX%20Horizontal%20Triangle%20Loop%20Antenna.pdf
    beacon_dave over 1 year ago in reply to kmikemoo +1
    Perhaps you need one of these: https://www.youtube.com/watch?v=qyVHzJ40JqM&t=1099s (18:19 into the video)
    Jan Cumps over 1 year ago in reply to beacon_dave +1
    I've found then lost it again 3 times now
  • kmikemoo
    kmikemoo over 1 year ago
    Here is a picture of the antenna in use today.
    For those that enjoy a challenge, here is a picture with a bit less zoom.  Can you find it?
    Even once you see it, it's hard to see it. Relaxed
    Not sure about the fox but I think we do have a tree climbing monkey in the vicinity
  • kmikemoo
    kmikemoo over 1 year ago in reply to beacon_dave
    beacon_dave Great job!  On the first hunt I hosted, I did climb a tree.  My wife was not thrilled.  She made me bring a ladder on the next one.  I did that for a couple more, but those collapsible ladders aren't exactly light.  That's when I broke down and bought a telescoping painters pole.  After about 2 years of supervising me hiding the fox - and promising not to climb any more trees, she has finally allowed me to go out on my own.
  • kmikemoo
    Just that segment by itself looks like it should be part of a Benny Hill skit. Joy
    beacon_dave over 1 year ago in reply to Jan Cumps
    There are a couple of nice optical illusions going on in that photo which are helping to the brain to make it blend into the surroundings.
    I spent too much time looking lower down initially as I didn't think people would be climbing the tree much above a few stout lower branches, so perhaps a couple of meters foot height with a couple of metres reach above that tops.
